Sponsored by: Real Truck
steering really tight. advice?
Old Sep 20, 2013 | 11:44 PM
m.qualls89's Avatar
m.qualls89
I've got an 04 f250 4x4 crew cab. I just replaced the upper and lower ball joints on both sides and also the drag link. My allignment was off from the bad ball joints so I had it alligned after I did all of this. Now the steering is really weird. Its like something is to tight. I can barely keep the truck straight because every time I barely move the wheel I seem to be going one way or another and getting it straight is nearly impossible to the point I look like a drunk driver. I can turn the wheel to go around a curve and let go of it and it will stay thay way until I turn it back. It won't return itself. I'm kind of lost so any advice is appreciated.
Old Sep 21, 2013 | 05:18 AM
tjc transport's Avatar
tjc transport
i ain't rite
sounds like the alignment is out of whack.
Old Sep 21, 2013 | 06:52 AM
mrod67's Avatar
mrod67
What brand ball joints did you use? Ive been having issues with napa chassis joints for this reason. I have been using factory joints lately because two jobs that ended like this. Making no money when you do it twice.
Old Sep 21, 2013 | 09:06 AM
m.qualls89's Avatar
m.qualls89
I bought aftermarkets because they were greaseable. I did have problems with the passenger side install. All seemed to go ok until I realized the ball joint stud on the bottom was somehow to long and hitting the u-joint. After I examined it and it all seemed to be right I wound up grinding the stud down. As for the allignment I just had it done and I even took it back and had it double checked. But I really didn't notice the issue until it was allinged. Not sure if that was because I was fighting it pulling to the right or not.
Talyn
Apr 8, 2011 09:41 PM
Bayer-Z28
15
May 7, 2010 09:47 PM
wrdabney
Feb 11, 2010 07:17 PM
jeeptroll
May 8, 2007 09:20 PM
lew2002
Sep 14, 2002 10:49 AM
