holy ball joints....
Old Apr 6, 2011 | 08:40 PM
Talyn's Avatar
Talyn
Don't do your own, ever
that sucked.
Probably okay if you do it all the time.
What a PITA!
Bought the 3 sockets I thought it could be at the store.
All 3 were wrong.
It was the 2 1/4 socket 4 prong.
Anyways.
Steering is tight! wooo!
Musta been the rest of my slop in that ball joint.
Old Apr 6, 2011 | 08:47 PM
Action4478's Avatar
Action4478
Steering is tight ..good ...or bad ?
Old Apr 6, 2011 | 08:48 PM
Talyn's Avatar
Talyn
Good.
Does what I tell it too now.
It's amazing on the TTB how much a bad ball joint will effect things.
Old Apr 6, 2011 | 08:50 PM
smash fascism's Avatar
smash fascism
Yeah those ball joints are a pain. did you also do the wheel u joints as well while you were in there?
Old Apr 6, 2011 | 08:53 PM
Action4478's Avatar
Action4478
Originally Posted by Talyn
Good.
How did you end up setting the bearings ?.......
Old Apr 6, 2011 | 08:54 PM
Talyn's Avatar
Talyn
no.
I wouldn't' have been able to get them out if I tried.
Would need a huge press.
The one didn't even have a clip in it anymore. haha. It wouldn't' budge. I hit it hard.
I wanna do a a d50, or d60 for under there.
Thinking bout converting a SD d50 with 450 knuckles or something. Depending on what I can make work
Old Apr 6, 2011 | 08:56 PM
Talyn's Avatar
Talyn
I did the feel method.
Tight was a bit to tight, so i backed it off 1/4 turn, then when you put the jam nut on, it tightens it back up a bit.
It spun with a bit of resistance, I called it good.
I know you dont want them completly free spinning and want a bit of resistance.
Give it a whirl and it turns a time or 2 and stops.
Bout where it was when I took it off.
Of all the things, the hardest was getting the axle shaft back into the slip yoke. Took me 30 mins!
Old Apr 6, 2011 | 09:04 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Man.. Those ball joints shouldn't be very hard to do at all. About an hour you can have the knuckles on the bench playing with a ball joint press.. LOL
Old Apr 6, 2011 | 09:09 PM
Talyn's Avatar
Talyn
Couldn't get the bottom taper to pop out.
Took me good hour and a half to figure out how to get it out.
I beat on it and everything I could thing of.
Finally finagled the ball joint press on it to put pressure on it and whailed on the top ball joint and it finally poped loose.
The problem is, I had nuts on both the ball joints. I had to cut them off cause the top one had stripped and the bottom one had stripped from the pressure from the press.
What a pain.
Old Apr 6, 2011 | 09:24 PM
strokin'_tatsch
Yeah, I remember my first go at ball joints.. It sucked. It's much easier after you've done it a couple times. Did you change your spindle bearings and everything while you were in there?
Krisx125's Avatar
Krisx125
lol, william ill try to get a video or sound clip of my ball joints. They mke THE WORST noise ive ever herd! Just waiting onmoney for my RSK so i can do my dana 60 swap!
Old Apr 6, 2011 | 09:27 PM
Talyn's Avatar
Talyn
No.
Would be silly to change 1 side of bearings and leave the other used.
The Spiral lock on the hubs was cool though. I didn't expect that getting in there.
I like the big hubs way better than them d44 hubs.
Same design, but a bearing instead of bushings.
Old Apr 8, 2011 | 01:03 PM
96 D.I.T's Avatar
96 D.I.T
it almost sounds like u didnt get the lock washer all lined up. the jam nut shouldnt make the adjustment nut move more than like 1/64 of a turn. i lerned the hard way, cost me $150 for new hubs and delayed me an hour on my road trip.
Old Apr 8, 2011 | 01:28 PM
Talyn's Avatar
Talyn
Yeah. that 1/64ths is techncially a lot.
Old Apr 8, 2011 | 09:41 PM
Mdt1992's Avatar
Mdt1992
took mine back apart last night to replace my passenger side axle shaft after it broke on me, but yeah its the same as a dana 60 4 prong spindle nut, i usually just run into the problom of getting the lock washer for the spindle nut and the darn spindle off, i was really not looking forward to doing it cause i had just had a hell of a time getting the spindles off of a dana 44 8 lug axle i have sitting in the garage that im rebuilding. the skin on my knuckles is gone from messing with the lock ring though, just a pain in the *** ha
