power upgrades
Old Sep 20, 2013 | 05:04 PM
bluemtn95ford's Avatar
bluemtn95ford
power upgrades
looking for some simple mods/upgrades for my 93 F250 7.3 IDI. mostly for power and tourqe but also exhuast sound. I have a 3 inch banks exhuast and k&n Filter. Everyone says a six inch exhaust is the way to go with diesel but it seems a bit overkill. Cold Air intake? turning the pump up a bit? Headers?(if possible on diesel)
Also, Im running what I believe to be a four inch lift. (add a leafs, no blocks) 35s. I dont beleive the PO did any gear changes, wondering if its worth it.
Im here to learn so everythings welcome, thanks
Old Sep 20, 2013 | 06:35 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
more than likely the gear swap will be your simplest performance mod.
Old Sep 20, 2013 | 08:02 PM
hairyboxnoogle's Avatar
hairyboxnoogle
One word, turbo
Old Sep 20, 2013 | 08:19 PM
idipleger's Avatar
idipleger
I'm new to this but I'm pretty sure a 4 inch exhaust will be plenty of flow. 6 inches sounds like a little overkill. When it comes to a re-gearing, what set of gears do you recommend and how difficult is it to find said set?
Old Sep 20, 2013 | 11:40 PM
hairyboxnoogle
Swap your rear for a set of 4.10s, will pull better, but mileage will suffer.
Old Sep 21, 2013 | 05:06 AM
tjc transport's Avatar
tjc transport
i ain't rite
and get rid of that k&n piece of crap filter.
they let dust particles through, and dust is a diesels worst enemy.
running a k&n filter is about the same as running no filter at all.
Old Sep 21, 2013 | 08:50 AM
idipleger's Avatar
idipleger
Awesome. Already running 4.10s and I get 17 mpg mixed driving. I don't think that is too bad.
Old Sep 21, 2013 | 09:17 AM
FORDF250HDXLT
if your turbocharged with one of the big 3,then 3" is pretty much all ya need.back in the day,banks did some dyno runs and claimed their 3.5" "monster" exhaust was good for a little bit over their 3" standard.so it's likely 3.5" is all the idi engines will benefit from.
"The standard Banks pipes and mufflers, as tested, have a 3-inch diameter, which has the ability to flow a lot more gases than the stock 2 1/2-inch system. An optional "monster" exhaust with 3 1/2-inch diameter tubing is also available. Banks told us that the larger-diameter system, which we did not test, is good for about 4 or 5 extra horsepower at peak rpm."
from 8th paragraph.
http://www.bankspower.com/magazines/...dewinder-turbo
Old Sep 21, 2013 | 08:04 PM
bluemtn95ford
I am turboed. One of the big three? and 4.10s seem a little high for 35s IMO..
Keep it comin and thanks for the help so far
Old Sep 21, 2013 | 09:25 PM
TheOtherStyle's Avatar
TheOtherStyle
The thing to remember here is that you have larger tires, which effectively made your 4.10 closer to 3.73 or 3.55 compared to stock tires. The taller the tire, the less turns it takes to go the same distance.
Old Sep 21, 2013 | 11:17 PM
ozdatman's Avatar
ozdatman
this is not too bad for tyre, diff calculations.
Speed Potential Calculator For Ring Gear And Pinion Changes
Old Sep 21, 2013 | 11:22 PM
hairyboxnoogle
There are plenty of options out there for more power. Having a turbo would have been one of the things you could have told us as far as things already done. Search button works wonders. There are currently multiple build threads going on to take a look through.
Old Sep 22, 2013 | 12:23 PM
bluemtn95ford
Okay thanks, also my turbo does seem to be outmatched by the manifold. What are my options for upgrading the turbo?
Old Sep 22, 2013 | 01:25 PM
hairyboxnoogle
Right now the common alternatives are an HX35 or an Aurora 3000. Which turbo kit do you have?
Old Sep 22, 2013 | 03:14 PM
bluemtn95ford
Im not sure, it was on when I bought it. It reads Garrett A/R 70 m43 on the Turbo itself.
