Regulated return help............please
Old Jun 2, 2012 | 05:44 PM
Shattered's Avatar
Shattered
So I just finished the plumbing for the return with fuel bowl delete, my big question is that now the stock fuel bowl is gone I know I have to put in a satelite fuel filter, does it matter if I put it before or after the pump on the frame?
Old Jun 2, 2012 | 05:49 PM
nlemerise's Avatar
nlemerise
Just make sure the filter you get will work push or pull and you will be set. I use a filter before the pump for years (used WIX and CAT filters). To the genral question, I don't think it matters one bit, but why not protect the pump?
Old Jun 2, 2012 | 05:59 PM
Shattered's Avatar
Shattered
the filter setup i got from napa, easily accessible, however I do have a water seperator filter before the pump. Will adding a regular fuel filter pre pump cause any issues?
Old Jun 2, 2012 | 06:01 PM
Shattered's Avatar
Shattered
Thanks in advance for any advice on this subject?
Old Jun 2, 2012 | 06:29 PM
joeyd61's Avatar
joeyd61
I used a 2micron after the pump..i also installed an air dog 150 before the pump as well...
Old Jun 2, 2012 | 06:53 PM
Shattered's Avatar
Shattered
yeah my next investment is a fuelab pump, but as far as adding another filter pre pump will still be ok?
Old Jun 2, 2012 | 07:59 PM
joeyd61's Avatar
joeyd61
What. Micron? 2 may be a little much for prepump. Pumpz are made to push more than pull
Old Jun 2, 2012 | 08:49 PM
beanhead6D5's Avatar
beanhead6D5
My pre pump is a 15 micron napa 3405,post pump is a 2 micron napa 3528. Filter housing is a 4770 napa.
Old Jun 2, 2012 | 08:56 PM
woodnthings's Avatar
woodnthings
You want to filter post pump. If your pump fails you could send debris through your injectors. Having a pr-pump and post pump is the best way to go.
Old Jun 2, 2012 | 10:13 PM
Shattered's Avatar
Shattered
I'm going to get another housing and filter next week and re-route and re-locate the pump and fuel lines. that gives me time to build a bracket for housings and machine a bracket for the regulator. she can sit for a week.
cabloom300
Sep 20, 2013 06:30 PM
whiteaddiction
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sep 10, 2012 02:25 PM
old76er
Nov 11, 2009 09:26 PM
robjs111
Jul 18, 2008 06:31 AM
killerkjn
Nov 3, 2005 02:58 AM
