P2262 code
Old Sep 19, 2013 | 09:44 AM
tcjhkbjt's Avatar
tcjhkbjt
P2262 code
I have an 04 F250 6.0 diesel with 175K miles. About a week or so i noticed there is not much power starting off but seems to get better as I drive. I took the EGR valve out lat weekend and cleaned it, but boy oh boy was it dirty. Put it back in but really didnt see a difference. Well yesterday when I got in it the check engine light was on, took it and the the code read and the P2262 was found. Could the ERG valve be bad or where should I start to look. I can hear the turbo whining as I accellerte but really have no clue what it is, need some help here. thanks
Old Sep 19, 2013 | 09:55 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
You may not have seated the EGR valve in all the way. Check it.
Also, check the MAP tube for obstruction.
Old Sep 19, 2013 | 10:24 AM
tcjhkbjt's Avatar
tcjhkbjt
EGR
ok ill check those things out, i dont have photobucket on this computer so how would I add a picture of the EGR valve?
Old Sep 19, 2013 | 10:28 AM
amdriven2liv
If you are able too.
Have your photo on the desk top and click on "Go Advanced" when you post next.
Scroll below and find "manage attachments".
If you can add attachments, that is the place you can do it.
Hard to take a picture of the EGR valve and if it is seated, tight in there.
Old Sep 19, 2013 | 10:45 AM
tcjhkbjt's Avatar
tcjhkbjt
I dont see where is says Go Advanced or add attachments on here. the picture is of the EGR when i took it out
Old Sep 19, 2013 | 10:59 AM
amdriven2liv
Sorry, you must not have that availability.
Send it to me if you like. I'll post it for you.
amdriven2liv@yahoo.com
Old Sep 19, 2013 | 11:24 AM
npccpartsman's Avatar
npccpartsman
P2262: Stuck turbo, MAP sensor, MAP hose plugged up; sensor unplugged, or leaking, CAC leaks, intake leaks, exhaust restriction, EBP sensor or EBP tube plugged. This code is set when MGP does not go above 5 kPa or 0.7 psi when the following conditions are met: rpm must be above 2800; VFDES above 20; and EGRVP is below 0.10. All of these conditions must be met for 5 seconds for the code to be set.
Old Sep 19, 2013 | 11:59 AM
amdriven2liv
Good list.
Here is his EGR valve.
Old Sep 19, 2013 | 12:10 PM
npccpartsman
Originally Posted by amdriven2liv
Good list.
I've seen hellacious worse. It's actually not that bad.
IIRC that "list" of conditions I posted is the detailed description of what causes that code as Bismic posted it. I do not know what all the abbreviations mean.
Old Sep 20, 2013 | 03:06 PM
tcjhkbjt's Avatar
tcjhkbjt
so should I lean more looking at the MAP sensor for now?
Old Sep 20, 2013 | 07:43 PM
Yahiko's Avatar
Yahiko
To the Original Poster (OP)
Here is a good how to post photos
https://www.ford-trucks.com/forums/1...he-forums.html
Sean
Old Sep 20, 2013 | 08:35 PM
m-chan68's Avatar
m-chan68
Before you condemn the MAP sensor, there are two things you can do. First, monitor BARO, MAP and EBP_A readings at key-on/engine-off. All three should indicate about 14.3 psi (or whatever atmospheric pressure is in your geographical location), give or take and be within 0.5 psi of each other. If all three indicate similar, pull the MAP sensor hose from the intake manifold and blow into it (YES, I said blow into it). Do you see the reading respond? If yes, you have no issue with the MAP sensor. If no, you likely have a blocked up hose, or the MAP sensor is faulty.
Old Sep 23, 2013 | 04:53 PM
tcjhkbjt's Avatar
tcjhkbjt
What is the easiest way to check the MAP sensor?
Old Sep 23, 2013 | 05:48 PM
Yahiko's Avatar
Yahiko
Like M-chan said Blow into it.
Just watch out for the black after mark from the hose.
Sean
Old Sep 23, 2013 | 08:26 PM
big inch's Avatar
big inch
That sounds like sticky turbo vanes to me. Do you have a way to monitor some pids?
