Need help
Old Sep 18, 2013 | 11:58 AM
tbugher62's Avatar
tbugher62
Need help
Need help guys,I have a 96 7.3 turbo diesel,the check engine light comes on when I try to start it,it starts a little rough then shuts down ,if I do it again and give it a little gas it stays running like there is nothing wrong with it.Took it get a code check and no codes come up,I did clean the engine compartment a little and add some tranny fluid yesterday before all this happened....please help!!!!
Old Sep 18, 2013 | 12:05 PM
madpogue's Avatar
madpogue
What scanner did you use?
Does the CE light go off when you are able to keep it running using the go-pedal?
Old Sep 18, 2013 | 12:12 PM
tbugher62's Avatar
tbugher62
Autozone scanned it,the ce light stays on
Old Sep 18, 2013 | 01:31 PM
mjunk1's Avatar
mjunk1
Do you have a spare cps you can change out? do you have a gauge to check the fuel pressure?
Old Sep 18, 2013 | 02:19 PM
superduty4x4's Avatar
superduty4x4
Check the wiring under the valve covers and going to the IPR.
Old Sep 18, 2013 | 04:12 PM
madpogue's Avatar
madpogue
Autozone's scanners can't read our trucks. You need a Snap-On MT2500, AeroForce Interceptor, DP-Tuner Infinity, or AutoEnginuity software on a laptop. If the CE light is on, there is a code.
Old Sep 18, 2013 | 04:51 PM
tbugher62's Avatar
tbugher62
How can a cps be bad if the truck starts running normal after a few trys staring it,also can a going bad cps trigger the ce light.
Old Sep 18, 2013 | 05:35 PM
Action4478's Avatar
Action4478
Your post is correct . CPS & or fuel won't set the light . Most likely oil . Is the C Case full ?
Old Sep 18, 2013 | 05:54 PM
ReBilld's Avatar
ReBilld
Good to see you on here Rick! Where you been hiding! LOL!
How did you clean the engine compartment? Did you spray with a water?
Old Sep 18, 2013 | 06:32 PM
madpogue's Avatar
madpogue
CPS very much CAN set the light. It's not an "all or nothing" part. There's at least a code P0340 and P0344, both related to CPS faults. When a CPS is faulty, it may or may not run the engine, and it may or may not set a code. In any event, you're groping in the dark until you can get the code(s).
Old Sep 18, 2013 | 07:51 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
And how old is your oil?
X2 on that.
Old Sep 18, 2013 | 08:30 PM
tbugher62's Avatar
tbugher62
Just briefly spray it off with water,oil is new and full,took it to a diesel shop so they can get me the codes,I will update after I get them.
Old Sep 21, 2013 | 01:10 PM
tbugher62's Avatar
tbugher62
Update,the Diesel shop checked my truck and said I must have got water somehwere on the engine that wasnt suppose to get wet when I washed the engine off,as everything checks out fine and the truck starts right up now that its dry.The shop said they dont exactly what not to get wet on the engine,so I need some of you here on this site to give some info on what not to get water on and or things to cover.I know guys that wash there engines all the time and have no issues,also semi trucks get there engines cleaned regularly.
Please give me some advise here...
Old Sep 21, 2013 | 01:36 PM
Mike Hannahs's Avatar
Mike Hannahs
What i thought was my cps killing my truck and setting my CEL turned out to be my fuel heater in the fuel filter housing shorting out,i changed my cps for nothing because it still did it and i went and unplugged that fuel heater and my problem was solved,it led me to think the cps was bad because the codes pulled up for it,maybe check that fuel heater im not saying its going to be the problem but it fixed mine good luck to ya
Old Sep 21, 2013 | 08:42 PM
madpogue's Avatar
madpogue
It was probably the IDM that got wet. It's the silver box on the inside of the driver's side fender. It has a vent that can let water in; sometimes it can even come in from the edge of the hood. You actually dodged a bullet getting it to start again; when the IDM gets wet, it seems to be about a 50/50 chance that you won't have to replace it.
