Australia Chapter Join Chapter , Leader: OPEN
JACK
Old Sep 18, 2013 | 07:56 AM
SSSimon's Avatar
SSSimon
JACK
I've been searching around for a decent F250 capable trolley jack.
The net is swamped with cute little alloy ricer jacks ATM, they were even stacked up in Costco - sexy little 'low profile' numbers - great if your ride is light & low.
I found this and jumped on - 685mm lift height:
https://www.tradetools.com/products/GJ5T
If there's any interest I post pics & review.
Old Sep 19, 2013 | 12:58 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I personally use this:
Heavy Duty 3 Ton Floor Jack w/ Rapid Pump
Only goes to 475mm, and only rated to 3ton, not 5, but I only use it for lifting the axles. I have a 6 ton bottle jack I use/carry in the truck as well.
Your's looks like a nice unit, we had a very similar one at Ford when I worked there for working on Effies, that we thieved from the truck division when they closed down (the plant they used to build tractors and Louisville Semi's )
Old Sep 30, 2013 | 06:19 AM
SSSimon's Avatar
SSSimon
Trade Tools jack - seriously HEAVY duty - 90kgs in weight, came in a steel reinforced cardboard + plywood box - 2 person lift.
Will make light work of the F250:
https://plus.google.com/photos/10776...13830402976812
jspence105
Nov 11, 2012 11:04 AM
Texas Chain Ring
22
Oct 4, 2012 07:57 AM
robles4242
Sep 30, 2010 03:15 PM
ntxlandman
May 19, 2009 06:39 PM
alanc77
Jan 3, 2007 10:27 AM
