upipe problems
Old Sep 19, 2013 | 06:48 PM
diehardstroker's Avatar
diehardstroker
well after 4 hours of working on ONE bolt i am beyond tired. ive hit this thing with heat, vibration, even a mini, hold it in your hand, jackhammer and it will not budge... i guess i got somewhere though, i got the nut off of it lol it unfortunately didnt take the bolt with it though.
Old Sep 19, 2013 | 08:35 PM
cuttn4fun's Avatar
cuttn4fun
had this same issue
I ended up getting mine out with alot of time and curse words. One was just too stubborn and I had to take my 4" grinder and cut off wheel and slice into the manifold toward the bolt. This allowed me to slightly spread the ear and the bolt came right out. Afterward I installed the uppies and with new bolt in place I took my wire welder out. Vice grips in place to "clamp" the ear somewhat closed around the bolt I zapped it back with a small bead. 6 months and it looks the same today as it did then. Just a thought if it comes to a last resort. I had messed with mine for 3 days solid before I cut my manifold.
Good luck
I did make sure to un-do the batteries before welding on the rig.
Old Sep 19, 2013 | 08:40 PM
diehardstroker
Hey thanks, that's reassuring, I'm not the only one. Unfortunately I don't have a welder lol I'm going to see if I can get the manifold hot red and hopefully that bolt will come out with a little persuasion if not ill probably have it taken to a shop down the road and have em do the rest. I can't have the truck down much longer
Old Sep 19, 2013 | 09:25 PM
Jesser02EX's Avatar
Jesser02EX
Mitch reading your post, with my bellowed uppies on the way, I've been spraying everything I have in the bolts! I'm using liquid wrench, PB blaster, sea foam product and looking for Kroil! I really hope it's not the same for me.
Good luck and keep us posted! I did buy some black and silver VHT paint for the exhaust side, compressor cover and uppies...
Old Sep 19, 2013 | 09:30 PM
diehardstroker
I hope not either!! I wouldn't wish this on anybody! It is how it is though!
That should come out pretty nice! I let my girlfriend pick out colors for under the hood she picked grabber green and plum purple hahahaha ill make it work though it'll come pretty cool I think
Old Sep 19, 2013 | 09:51 PM
Jesser02EX's Avatar
Jesser02EX
Mitch just researching broken stud removal and noticed many suggest after heating up the bolt, use candle wax to help lube up the threads. The wax is sucked in to the heated area.
Just a suggestion!
Old Sep 19, 2013 | 09:54 PM
diehardstroker
I will definitely try that! Thank you very much for looking that up! Weather says its supposed to rain here tomorrow and I can't fit the truck in the garage so I'm.not sure how much ill get to work on it
Old Sep 19, 2013 | 11:08 PM
JT250's Avatar
JT250
mine came out pretty easy. hope you have the same luck. not much rust here in OKC.
Old Sep 20, 2013 | 08:20 AM
Jesser02EX's Avatar
Jesser02EX
Good to know! The rust on mine appears to be from just the excessive heat at the manifold. Nevertheless, I'm not taking chances, I need this to be a bolt off/ bolt on project for me.
Old Sep 20, 2013 | 08:25 AM
diehardstroker
Murphy's law=if something can go wrong it will go wrong. My family has the last name of Murphy so this rule always applies!
Old Sep 20, 2013 | 12:04 PM
Smokiesman's Avatar
Smokiesman
If trying to heat with a propane torch I would switch to Mapp gas bottle much hotter!! Good luck!!!
Smokie
Old Sep 21, 2013 | 12:05 AM
diehardstroker
thanks for the suggestion smokie, I decided to let it rest (and myself) for today, but ill be back at it again tomorrow, I have one last thing to try then ill be looking for Mapp gas botlle, pb blaster and bust out the candles!
Old Sep 21, 2013 | 06:18 PM
  #28
diehardstroker
well today was just not a good day. My dad thought he was helping me out by moving (yes he started it) the truck to a dry spot in your driveway so i could work on it when i got up, well the turbos out and nothings plugging the holes on the pedestal, and you can all guess what happened... please, please please tell me that nothing couldve got damaged from this?? its very low on oil, it hasnt been started since cause its so low. we managed to push the 8000lb monster back into its orignal spot after cleaning up the massive oil spill. but please reassure me that nothing can get broken from this happening....
Old Sep 21, 2013 | 07:14 PM
  #29
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Nothing should be broken. Just clean up and fill it back up with oil and continue what you were doing!
Old Sep 21, 2013 | 07:19 PM
  #30
diehardstroker
alright thats a relief!!
I went and got the Mapp gas bottle that smokie recommended, how long should i heat it up for? i still cant get that darn thing out...i even broke out my air hammer.
