This sounds like a transmission issue, specifically a problem with the downshift. If the engine is revving at a high RPM and the truck isn't downshifting to first gear, this could indicate a problem with the transmission control module or a mechanical failure within the transmission itself. I would suggest having the truck inspected by a mechanic to diagnose and fix the issue.
