Wheel Adapter Thoughts
Old Sep 16, 2013 | 05:35 PM
Ripcity's Avatar
Ripcity
Any of you running wheel adapters that go from 8x6.5 to 8x170mm? So you can run the newer super duty wheels?
Your guys thoughts and ideas and experiences before I do it.
Thanks
Tim
Old Sep 16, 2013 | 05:52 PM
Sooper Camper's Avatar
Sooper Camper
people do it all the time. loc-tite is your friend. you will increase the track width of the truck about 3", so keep that in mind. add up the ~$100 per set x2 and it makes less sense to me than just buying the right wheels in the first place.
Old Sep 16, 2013 | 07:31 PM
Blue and White's Avatar
Blue and White
Iron vs Aluminum would matter to me. I used forged aluminum 3/8" spacers on a car once. I would not use aluminum of any type for either spacer or adapter on a 3/4 ton or heavier truck. There is just too much pressure and load which can work and relax the joint.
Old Sep 16, 2013 | 08:52 PM
Schickel's Avatar
Schickel
If its for show and no go I don't have a problem with them but if you plan on offroading hauling or towing I wouldn't trust em
Jun 28, 2021 08:26 PM
chukar
Feb 7, 2016 05:54 PM
masegtx
Mar 12, 2009 09:19 AM
whitlow33
Dec 16, 2007 02:23 AM
TrueBlueV10
Aug 4, 2003 07:55 AM
