new dist install issue
Old Sep 13, 2013 | 03:32 AM
OrdoDraconis's Avatar
OrdoDraconis
pretty sure my timing is way off when i went to start my truck after the new distributor was in stalled (ds2 + msd) it back fired through the carb kinda lost as to what to do now and praying i didnt jack anything up. any suggestions.
Old Sep 13, 2013 | 06:39 AM
AbandonedBronco's Avatar
AbandonedBronco
Heya neighbor!
When you put the new distributor in, did you install it from base 0? Or did you mark which direction the old one was facing and try to duplicate it?
Generally, I like to start from scratch and never worry about trying to get the new distributor lined up just like the old one.
First thing to check if you did start from scratch, are you sure you didn't install the distributor 180° out? It's easy to do if you get the compression and the exhaust stroke mixed. I've done it before and the symptoms are usually no start, and popping back out the carb.
The other is getting the stator inside the carb lined up with the pickup magnet. When you line up the carb, you have to take off the rotor, look down in, and line up the closest arm on the stator between the two marks on the black magnet. Easy to do, but if you don't, just a little bit of error can cause your timing to be way off.
Best of luck.
Old Sep 13, 2013 | 09:39 AM
OrdoDraconis
i think you mean the distributor on the second part. i started from scratch. ill have to give the look at the strator when i get off work monday i work twelves fri sat and sunday so i pretty do nothing on the weekend beside work. and ya thats what i was thinking is that i have it 180 out
Old Sep 16, 2013 | 06:38 PM
OrdoDraconis
ok so i had the msd key on wire hooked up got it started and ran but once my fuel filter emptied it died its not getting fuel i do have dual gas tank did i end up pulling my relay? when i removed the harness there was a relay next to my ecm???
Old Sep 16, 2013 | 08:55 PM
OrdoDraconis
problem resolved my 1/2 drive gun was laying and pinching the rubber line from the frame to my fuel pump .......
surf-SIX
Jan 2, 2016 07:46 PM
sharikmate
1978 - 1996 Big Bronco
Aug 22, 2015 10:21 AM
ndmccann
Oct 8, 2012 01:11 PM
brownstraightsix
Jan 17, 2006 10:27 PM
barca_texas
25
May 22, 2005 12:10 AM
