Trouble finding A/C parts
Old Sep 13, 2013 | 01:44 AM
jerry73's Avatar
jerry73
I've looked all over and checked all my sources and can't find and a/c vent ducting...anyone have any ideas where to check or know where to find it? Thanks in advance
Old Sep 13, 2013 | 01:47 AM
jerry73's Avatar
jerry73
Also the rubber gasket on the two hoses coming out of the a/c unit ,it's about 1/4" thick and shaped like an M to fit around the big think inside that looks like a radiator...not the heater core the other one
Old Sep 13, 2013 | 09:14 AM
mikeo0o0o0's Avatar
mikeo0o0o0
They are no longer available, there are no dealers or obsolete suppliers that have any. No one reproduces them either.
Your best bet is Ebay, I see them on there fairly often.
I'll check on the gasket but I believe its going to be the same deal.
Is this for a '73? The gasket changed in late '75.
Old Sep 13, 2013 | 09:23 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Seal, A/C evaporator tube to case
73-75 F100-350 w/ integral A/C before s/n W00,001
Inner D3TZ-19B552-A not replaced*
Outer D3TZ-19B552-B not replaced*
*These parts were never offered by Ford over the counter as replacement parts so there will be no dealer or obsolete supplier that has any.
Old Sep 13, 2013 | 09:31 AM
mikeo0o0o0's Avatar
mikeo0o0o0
If you still have the steel skeletons left from the old duct you might be able to do something like this:
https://www.ford-trucks.com/forums/1...l#post13401919
Or, if you locate a decent set, you could do something like I did on my restoration project. Hopefully this will help preserve the ducts for a while.
https://www.ford-trucks.com/forums/8...l#post12294219
Old Sep 13, 2013 | 06:34 PM
V10man's Avatar
V10man
I found a 78 duct on craigslist. it is hard plastic & used a short piece of flex duct. I talked to the guy and he says the flex piece is rotted but all there. He was asking $40. If this will work for you send me a pm and I'll get it for you or talk to him and see if he'll ship. Parting out 1978 F250 4x4 XLT Pickup Truck Snow Fighter Dana 60
Old Sep 14, 2013 | 12:26 AM
Higbean's Avatar
Higbean
Would the ducting from a 78 work? I just pulled it all out of my parts truck and it's cherry! Looks like NOS except the defroster part. Maybe we could work out a deal.
Old Sep 14, 2013 | 02:43 AM
jerry73's Avatar
jerry73
May try my luck at pick n pull but I do have the skeletons. And yes it's a 73
Old Sep 14, 2013 | 09:50 AM
tbear853's Avatar
tbear853
A lot of it will swap '73-'79. When I installed factory AC in my '77 back in 1986, I stripped all AC stuff from a wrecked '73 at a friend's JY and a '79 crew cab at another yard before it was crushed, and I used best parts from each noting some small differences. Used '79 housings, vac pulls, and '73 heater core and '73 controls, and as I recall ..... the '79 plastic ducting but the vents from the two years were near same .... I think? I vaguely recall that even back in 1986, the '73 wire with cloth ducts were deteriorated.
Anyway .... still works, though I'ld probably trade it all for a factory firewall section to graft back in and heater parts (but I'ld still keep the ducts in the dash cutouts I guess) .....
I never use the AC in the '77 these days (though I did use it a lot in the 15 or so years after I made the swap) and it takes so much room under hood. Likely some day I'll just make it a fancy heater / vent and remove AC Compr / evap / etc.
Now that I think on it ..... gonna have to go take a look under the dash.
Old Sep 14, 2013 | 10:55 AM
jerry73's Avatar
jerry73
Nice! You wouldn't happen to have a diagramed for the vacuum would you?
vidaliaman
Nov 26, 2017 03:48 PM
35&78Ford
Mar 20, 2017 11:21 AM
merkswitch
1983 - 2012 Ranger & B-Series
Feb 18, 2016 09:27 PM
544tess
22
Nov 16, 2015 06:07 PM
usmcclark
1947 and Older Ford Trucks
Oct 16, 2012 09:24 PM
