head interchange
Old Sep 12, 2013 | 08:36 PM
broketruckjohn's Avatar
broketruckjohn
head interchange
my 92 302 has stock heads (truck 4x4) it was brought up that explorer heads will benifit my truck. what should i look for as in year make model physicall apperance.thanks
Old Sep 12, 2013 | 08:53 PM
Conanski's Avatar
Conanski
Yes your motor would benefit from heads but it will benefit more at this point from a cam upgrade, the stock cam is needlessly small and restrictive. The '94+ factory truck cam commonly referred to as the F4TE cam is a healthy upgrade.
The heads you want are from a '96 to '97.5 Explorer or Mountaineer, a '93-95 Mustang Cobra, or a Gen1 Lightning. The heads are identified by 3 vertical bars(lines) on the ends and by the letters "GT" on the outside corners.
Old Sep 13, 2013 | 06:35 AM
broketruckjohn
head interchange
ok great. my 302 has a true roller timing gears, .40 over pistions, summit sum-1790 street strip cam, edelbrock dual plane high rise intake edelbrock 650 carb. accell high energy ing. so far this is the best set up. 15426378 F/O .035 plug gap .017 point gap 12 degrees btdc full manifold vac on dist.
Old Sep 13, 2013 | 10:55 AM
Conanski's Avatar
Conanski
Oh ok.. I assumed your motor was all stock. GT40 heads flow about 20% better than the E7's so you would see gains across the board with that upgrade on it's own.
Old Sep 15, 2013 | 07:36 AM
broketruckjohn
heads
another trip to the scrap yard (parts store).haha
Markybe
Dec 3, 2018 10:32 AM
Midwest82
Jul 16, 2012 03:00 PM
93F22A6
22
Apr 29, 2009 10:10 AM
jerg_064
17
Aug 8, 2008 12:13 PM
monkei
1978 - 1996 Big Bronco
17
Aug 31, 2004 07:21 PM
