Sticky lifter
I have a '66 F100 with (I think) a 352 V8. One lifter on the front cylinder passenger side is sticking. It is clicking pretty bad. I tried the Marvel Mystery Oil out yesterday, but after 15 minutes of idling, it is still sticking. I took off the valve covers to see if others had problems too. I noticed a lack of oil on that passenger side. I'm wondering if maybe the oil passage has gotten plugged or something, and the problems are related, or if they are just coincidental? The drivers side was noticibly wet from oil, but this also could have been from me pouring in the MMO earlier. I couldn't feel any noticable play in any of the other push rods. I've been told I need to pull off the rocker assembly and check the push rod for straightness, any other suggestions would be appreciated. Would running some oil down the push rod onto the top of the lifter do anything?
Some background on the motor...... I just got the truck and the engine is either a replacement, or been rebuilt due to it being blue and having liquid gasket material. I assume it is a 352. I know it is FE.
Thanks,
Joel
I think I would measure the valve lash before getting carried away. I like to loop a piece of wire coat hanger around the rocker then use my seal remover (it's the lever type) to slowly compress the lifter. With the lifter fully compressed measure between the valve stem and rocker arm with a feeler gauge. 0.1 to 0.2 inch is allowable with .1 to .15 desired. With #1 on TDC compression measure #1-I, #1-E, #3-I,#$-E,#7-I,#5-E,#8-I,#8E. Then rotate crank 360 deg and measure the remainder. If all the lash meas. are in spec you can go after sticky lifters or lack of oil.
The next thing I would do is pull the rocker shafts, follow the right procedure here or you can damage things. With the shaft off inspect the springs that hold the rockers apart carefully, if they are broken they can cause 'lifter' noise. I would take them apart and clean everything in parts dip then re-assmeble making sure the oil holes are in the right place and there is no play in the rockers or stands. This is a good time to check the pushrods for strightness as well, roll them on a flat surface (I use a 12"x12" mirror tile) if it's bent you can see it.
Assuming everything so far has checked out or been replaced, reinstall the rocker shafts making sure the bolt with a smaller shaft goes in the big hole in the head - this is where the oil comes from. On the passenger side it's second from the back, on driver's side it's second from the front. Also make sure you put the right shaft on the right side, the notch goes down and forward on the passenger side and down and aft on the driver's side.
It's just me but I would check the valve lash again at this point.
If you still have noise at this point, fire it up with a valve cover off and watch for oil at pushrod end of the rockers, if no oil here you either have very low oil pressure or a restriction in the oil gallery or both. If the rockers oil OK the lifter(s) are sticky, you can either replace it/them or run the MMO for a while to see what happens - there's a good chance it will clear up.
Just so you know, it is possible too chenge lifters on an FE without pulling the intake. You need a lifter removal tool, it's a standard item. You put the tool thru a pushrod hole and 'catch' the snap ring in the lifter then pull it out of the bore. On the end holes you have to drop it in valley then move over to the nearest big hole to fish it out. It's a little tricky and time consuming but it beats the hell out of pulling that heavy, heavy manifold off.
Sorry for the length but there's no short way to describe it.
70fordguy, if those lash measurements are out of spec., that means buying longer pushrods right?
Thanks,
Joel
Joel
New shafts are only $20-$30 and rockers run in the $15 range.
OBTW. max OD on the shaft is .840", min is .839.
Shaft to rocker clearance .002-.005".
Rocker arm bore .842 - .844".
If you're gonna get the mic's out you may as well have all the right numbers - That Ford shop manual is some of the best $$ I ever spent.
