L&L Header question
Old Sep 10, 2013 | 07:12 PM
gschembs's Avatar
gschembs
L&L Header question
other than cutting some inner fender well is there anything else that needs relocated with the out the fenderwell headers? also what kind of power increase do you typically get from changing to headers of iron manifolds?
truck is a 1977.5 f250 with 460 and c6 auto.
Old Sep 10, 2013 | 07:29 PM
keiths78f150's Avatar
keiths78f150
No other modification needed.
You really won't see much power...maybe 10hp? It just allows the motor to breathe better.
Old Sep 10, 2013 | 08:47 PM
ranger429's Avatar
ranger429
Might need to notch the passenger side cab mount, header comes close and touches on some.
Old Sep 10, 2013 | 11:17 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Maybe the bracket attached to the frame that clamps the brake line, just aft of the shock tower?
And removing the tower might aid in installation? It should be bolted on, if you are putting them with the engine installed.
I had to grind a little clearance on the dvrs side cab mount bracket.
Old Sep 11, 2013 | 09:31 PM
NMFirstF2504X4's Avatar
NMFirstF2504X4
I had to trim the inner fender well on both sides. The passenger side cab mount and bolt needed ground back some as well. As '77&79F250' suggested, I had to remove the brake line clamp on the driver side. Finally removing the shock driver side shock tower was a necessity to get them in. Here's a link to a thread I started back when I was going down this road.
https://www.ford-trucks.com/forums/1...it-pics-2.html
Old Sep 11, 2013 | 10:50 PM
KIKKUP's Avatar
KIKKUP
What they said already plus... I had to install a dent on one of the driver's side tube as the steering shaft needed just a bit more room to rotate without hitting.
Test fit before coating!
velcro7279
Dec 11, 2017 08:19 AM
Scolesy8
Mar 6, 2009 04:11 AM
heavy78
Aug 6, 2007 10:38 PM
goonski
Oct 7, 2005 12:18 PM
jowilker
Oct 10, 2001 11:34 PM
