F100 wheeler build
11-20-2013, 04:40 PM
Of Ive got the itch or fever, what I dont have is the Piggy bank to scratch that itch!
11-22-2013, 05:51 AM
THAT IS MORE THAN ENOUGH!!!
NEXT TIME YOU WILL BOTH GET A TIME OUT.
11-22-2013, 06:01 AM
O yea, that explains my
[/URL]
When I had a quote n response I tried to post.
11-22-2013, 09:08 AM
Guess i missed something...
11-22-2013, 11:47 AM
It was between 11 pm yesterday and 1am this morn.
11-22-2013, 01:14 PM
11-22-2013, 03:28 PM
on
I thought we were starting to get along. Guess I missed something too
11-25-2013, 09:58 PM
on
Beefed up the knuckles
led tail lights in progress
11-26-2013, 10:48 AM
I am borrowing/straight up stealing that idea for my 71 Bronco, ok?
12-11-2013, 12:06 AM
on
Quote:
Originally Posted by
77&79F250
okie dokie.
Drove it out of the shop. It's nowhere near driveable, but it was nice to move it under its own power again
Trimmed the fenders some more, flexed it and I need to give it another trim
Changed the rear spring perches to a little bit taller ones. Started making a traction bar, then ran out of bushings/joints, so I moved on to mounting the shocks while I wait for parts to show up
Been thinking about going crazy with the paint, like this
12-16-2013, 01:18 AM
on
Rear shocks are mounted, and the rear brake lines are all ran
Droop, about as much as you would expect from stock leaves
12-16-2013, 06:42 AM
12-22-2013, 01:43 AM
on
Rear bump stops
12-27-2013, 10:11 PM
on
Been plucking away at this thing.
Got some coils
Built up the spring plates so the u-bolts don't tear up the bumps, obviously need to cut down the u-bolts still
Plumbing in a proportion valve
01-05-2014, 10:39 PM
on
Got the front limit straps, brakes, and brake lines done. Almost ready to pull this pig apart for paint and final welding
