F100 wheeler build
Old 09-09-2013, 11:54 PM
lucky_thirteen
lucky_thirteen is offline
lucky_thirteen is starting off with a positive reputation.
F100 wheeler build
Started like this, had a 302/np435/dana 21
Built a rear bumper for it shortly after
After a while it got 35's, 4.56 gears, and a rear spool
Got a different daily driver, and this wend under the knife. 63" Chevy rears mounted under the frame, ho72 axle with 14 bolt guts, and some 42's
lucky_thirteen
Yarded this junk out of the front end, and built a front bumper. There's a winch in there, just need to order a fairlead and cut out the hole.
New running gear. 4sexty/np435/203/205
Got the dana sexty set under it, the steering box mounted, and the three link under way
This little guy doesn't let me have too much time to work on it
Old 09-09-2013, 11:55 PM
lucky_thirteen
Making some progress, things are tight under there
Clicky
Getting some welding done on the front
Old 09-10-2013, 05:28 AM
kjett's Avatar
kjett
kjett is offline
kjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to beholdkjett is a splendid one to behold
Looking good.
Old 09-10-2013, 06:49 AM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
Damn right it does
Old 09-10-2013, 06:07 PM
77mud's Avatar
77mud
77mud is offline
77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.
NICE!!!!!!!!!
Old 09-10-2013, 07:07 PM
460 FORD MAN's Avatar
460 FORD MAN
460 FORD MAN is offline
460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.460 FORD MAN has a good reputation on FTE.
That's badass. I like the bumpers.
Old 09-11-2013, 03:00 PM
wyckedcombo17's Avatar
wyckedcombo17
wyckedcombo17 is offline
wyckedcombo17 is gaining momentum as a positive member of FTE.
That thing is frickin sweet
Old 09-11-2013, 09:14 PM
lucky_thirteen
Thanks guys
Old 09-16-2013, 12:50 AM
lucky_thirteen
Built me a diff cover. Hopefully the hydro assist ram will show up tomorrow so I can get that mounted
Old 09-16-2013, 03:17 AM
fatdan460
fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
i liked your work better when you were dying of cancer.
Old 09-16-2013, 06:06 AM
alpha/omega
High level of kickassableness detected.
Old 09-16-2013, 01:26 PM
fatdan460
see folks, this is what happens when dan gets sick and calls in to work, then fells better around 10 at night and decides to drink and use the internet. what that post was supposed to read as was "i miss the orange truck and wish you were still working on it instead of selling it off." this concludes today's edition of deciphering dan.
Old 09-22-2013, 11:40 PM
lucky_thirteen
Classy
Thanks.
Found a little bit of time today, got one side of the ram mounted
Old 09-23-2013, 03:47 AM
fatdan460
well, now i liked you better when you weren't prissy. you used to have a sence of humor. you also used to have cancer. coincidence? i think not :fo2:
i appologized, so try not to be a jerk like me from here out, ok?
Quick Reply: F100 wheeler build
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
