looking at a 97 powerstroke
#91
I have a friend that works for the German company that supplies BMW and maybe Mercedes with their soundproofing materials. I have a bunch of sheets of the stuff in the garage but have never put it in. He said you don't put down a whole layer, just some pieces in certain places and it "captures" the noise. It's a 1/4" thick semi-flexible material. Has sticky on one side. I'll ask him about it and try it out. Maybe send you some if you want.
Well Glenn, after my ride home sunday I'm almost thinking of moving my exhaust exit to the stock location instead of ahead of the rear tire. It was real loud with the windows down on the interstate. I like it loud, but man that ride was noisy!
I wonder how much quieter the cab would be if I moved it back?
My wife is really sensitive to sound and she wears ear muffs from a sports outlet store. Sometimes ear plugs under that!!
#92
Well great. I have heard the up-pipe gaskets are a real PITA too...ah well. I'll have to crawl under it tonight and have a look. Hopefully they aren't rusted through or something like that. I feel dumb now...didn't even think abotu those leaking. I bet I am losing a good amount of boost.
wonder how much an after market pedestal is?
so should the linkage be pushed in n wired or pulled out n wired or just left alone. don't know how to tell if its gutted. take the snap ring off n pull the guts out??
I also think the puffs of exhaust are coming from my up pipe leakin a lil.
Riffraff Diesel: Garrett TP-38 Blank/Deleted Pedestal 94-97
The rod you're looking at can be just left alone or cut off. The linkage you want to wire up is the arm on the bottom of the butterfly valve shaft on the turbo outlet. I'll try and snap a picture of mine tonight. The PO of my new truck had this one wired open.
#93
#94
Nate, I definitely have soot stains on the firewall and can smell exhaust coming through the vents when idling. The soot stain is pretty big and it covers the trans dipstick. I cleaned it once with de-greaser and a hose, but after 2 weeks it was the same. I need to replace up-pipe gaskets!! So, have a shop do it or do it myself? I am thinking that a shop near me that I trust implicitly is the way to go? Unless it is fairly easy to get to myself....looks tight though.
#95
#96
#97
my up pipes only have a little black rite where they bolt together, not blowing it any where yet. think I will wait to tackle that project later. lol
my boy had to take the truck out of town for work a few days so I cant look at the ebpv thing until tmw.
starting to get chilly in the mornings so I have to get after the glow plugs.
I saw a test on one of the web sites of three glow plugs side by side. showed them put power to them n how they worked. side the rx was best.
rx, ngk and beru I think were the 3. any comments on which one.
rosewood diesel is where I saw the test comparison.
#99
#100
Good deal. Savvy and ability isn't as much of a question as is time to do it, what happens if I break a bolt, etc. I talked to my diesel guy and he said 275 for the pipes and 400 labor to do the work. I figured that isn't too bad considering I now know what the job entails. I am just wondering if I should just go ahead and do the bellowed or not? I am still getting to know this stuff about this truck. After this, I should be good for a little while as I get $$ and other plans together.
#101
#103
That's not a bad deal at all in my opinion. As for the bellowed up-pipes, I would say not to waste your time and money with it unless you intend never to change the turbo out for something aftermarket (T3 or T4 frame) or you can build them yourself. They are SPENDY! If you do an aftermarket turbo, you'll likely end up replacing them anyway.
Sorry!! Back on topic!
#104
Nate, I really appreciate the input. That answers my question for me. I don't intend to change out the turbo anytime soon, I just more wanna get my truck really tight and buttoned up. Longevity with minor performance is my goal, so it looks like I'll just be doing stock pipes for now. I'd rather put the money towards e-fuel and that sort of thing. Thanks again!
just got my truck back tonite so I can tinker some more this weekend. going to check this ebpv thing out some more also try and figure out if I have an after market down pipe or not. I can feel a wrinkle in the bend. are the after market ones wrinkle free??
anyone use the tymar intake? is it the same filter as the 6637? just different brackets n tubes. like the looks of it, but 60 bucks more.
#105
Aftermarket downpipes are round going down after the turbo. The stocker is flat and pancaked.
A few have used the tymar intake. I don't think its any better, and iirc its the same filter. I had a tymar downpipe, 3" on top to 4" on the bottom. It is a very good piece. It has since been modified and combined with the downpipe that came with my S366.
