looking at a 97 powerstroke
#77
That's kind of neat your mpg's are so close between the two over the last two years Glenn. I honestly got 20 with mine if I drove 55-60 before my last mods, gear swaps, etc. I got 2 better towing too, but I always had to back out of it for egts. Now, I'm just like you, I spent the money, I'm gonna work it as hard as it will take! Just gotta get my studs in this winter so I can push it even a little more if needed!
#78
#79
i plan on pulling a 4 place snowmobile trailer with mine. was hoping for 14 0r 15 mpg's. from the sounds that might not be. lol
i don't see anything else to hook that linkage to. wire was unplugged. so i take it if its unplugged it should be normally open right??
just don't like it stickin out there doing nothing. can u get a pedestal off something else that doesn't have the valve in it?
#80
I know it sounds like I'm complaining, I'm not. Another reason I just let it go pulling, especially if I'm using the cruise, its pure entertainment to me. Its like going to the movies and watching all the gauges jump into action. OK, OK, put me in a straight jacket in a padded room,
Yeah, it is pretty interesting. For four or five years before these last two years of record keeping I didn't want to know, LOL. When you put it down on paper it tells a story. Sound proofing, sound proofing and more sound proofing will be my mods this winter. Behind the dash, doors, ceiling, floor and under the hood. I might even have it undercoated, not that I'm worried about rust but it would help the noise.
#81
I have already done the dynamat on the floor. I was thinking about new carpet, is the jute like a carpet pad? What is the coozie mod and door seal mod?
#82
#83
I have read that the pedestal is a real PITA to get off. Is this true? I am guessing what you just described is what I see the little puffs of exhaust coming out of? My next question is..why in the world would someone do it this way?
#84
I'm guessing that the little puffs of smoke you're seeing are coming from a leak in one of your up-pipes. And yeah, pulling the pedestal can be a real chore. It's not impossible, but the first time you do it, it will take a while. I don't really see any issue with the actuator rod being the way it is. It's unhooked and as long as the EBPV is either gutted or wired open, you should be good to go. Especially living in CA (it's not like you need the low temperature help).
#85
I have a friend that works for the German company that supplies BMW and maybe Mercedes with their soundproofing materials. I have a bunch of sheets of the stuff in the garage but have never put it in. He said you don't put down a whole layer, just some pieces in certain places and it "captures" the noise. It's a 1/4" thick semi-flexible material. Has sticky on one side. I'll ask him about it and try it out. Maybe send you some if you want.
#86
Well Glenn, after my ride home sunday I'm almost thinking of moving my exhaust exit to the stock location instead of ahead of the rear tire. It was real loud with the windows down on the interstate. I like it loud, but man that ride was noisy!
I wonder how much quieter the cab would be if I moved it back?
#87
Received 3,912 Likes
on
#88
#89
I gotta agree, I do like it loud, but this was almost too much for a long time. If I can get another oil cooler on I'll be able to keep temps down better and leave the windows up and ac on. Then I won't have to worry about it.
#90
