Boneheaded No Start Issue
Old Sep 9, 2013 | 11:08 AM
jdbatzer's Avatar
jdbatzer
4wd Low
I've got the 2006 6.0L diesel... 95k miles... recently changed fuel filters (5k miles ago). Got the water in fuel light so I thought I'd drain the water separator.
ALL I did was drain the water separator... what I didn't do was cycle the engine/fuel pump three times. I got distracted by work and just started the truck and drove off. A couple of miles down the road and the truck sputters and dies. I tried cranking it with no success. I cycled the system several times and cranked again with no success. I know there are tons of resources on here to search through, but I only have a few minutes to be online. If the truck needs to head to the shop I'd like to send it in today. Anyhow, any help would be appreciated.
Thanks! ~ David
Old Sep 9, 2013 | 01:14 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Check the upper fuel bowl for fuel. I've done the same as you and ended up finding I did something wrong with the filter install.... removed cap right there in the middle of the road and reinstalled. Turned key on/off 3 times and away I went.
UPDATE: OOPS!!! Didn't see the filter change 5000 miles ago....sure ain't that!!
Old Sep 9, 2013 | 03:21 PM
big inch's Avatar
big inch
I have had a few trucks that were hard to start after replacing the fuel filters or otherwise opening up the fuel system. What I have had to do is remove the secondary filter up top and cycle the key until fuel filled the housing. The lower the fuel level in the tank, the harder it is to bleed the system.
Old Sep 9, 2013 | 03:54 PM
jdbatzer's Avatar
jdbatzer
4wd Low
Thanks for the replies... now I have somewhere to start! I'll give an update when I have one
Old Sep 9, 2013 | 04:09 PM
Maxium4x4's Avatar
Maxium4x4
Start with simple items first, like, do you have fuel in the tank? Just because it reads full, is it?
Old Sep 9, 2013 | 05:15 PM
Misky6.0's Avatar
Misky6.0
Thanks! ~ David
Filters replaced 5k miles - thus not likely to be a filter issue....
If ALL you did was drain water separator, make double sure you put it back in.
It might have fallen out if you forgot to tighten it?
Old Sep 10, 2013 | 02:13 AM
run6.0run's Avatar
run6.0run
I've heard of people cycling the key to prime the system after fuel filter changes or HFCM drains, I've never done it tho. I change the filters, turn the key on for about 10 seconds, fire it up, and have never had an issue. I also drain my fuel separator every oil change. Fuel filters every other oil change (10k). I've done fuel filters over a hundred times on my personal trucks too. 110 actually.
Old Sep 10, 2013 | 09:25 AM
jdbatzer's Avatar
jdbatzer
4wd Low
Update... checked the water drain this morning and looks like the rubber seal is bad. Not sure what all that could cause, but loss of pressure in the system (?) and loss of fuel come to mind. Anyhow, gonna get that fixed, fill her with diesel, and try it again!
Old Sep 10, 2013 | 09:41 AM
Misky6.0's Avatar
Misky6.0
get the updated (knurled ****) brass version, I think even the Ford dealer has it now. No more using an allen wrench..
Old Sep 10, 2013 | 11:12 AM
run6.0run's Avatar
run6.0run
And remember,,, torque doesn't seal the plug,, the oring does. Finger tight until the oring seats.
Old Sep 12, 2013 | 08:48 PM
jdbatzer's Avatar
jdbatzer
4wd Low
Thanks for all the help guys! New brass plug and o-ring, primed the system and it started right up. Next up is the blue spring upgrade - sure I'll have some questions when I do that, too
Old Sep 12, 2013 | 08:53 PM
Maxium4x4's Avatar
Maxium4x4
Good to hear you got it figured out.
Rudiak
6.4L Power Stroke Diesel
27
Feb 1, 2022 12:08 PM
oldgrasshopper
6.7L Power Stroke Diesel
17
Jan 17, 2016 12:02 PM
MucksCo
Oct 27, 2012 11:42 AM
79OldBone
Jan 9, 2012 10:49 AM
wizard
Nov 16, 2008 03:52 PM
