Gas tank replacement
Old Sep 9, 2013 | 12:55 AM
jgavac's Avatar
jgavac
I did some searching here on the forum, but can't seem to find anything. Is there anyone out there who makes replacement in cab gas tanks? Poly would be preferred, but I'd take metal too.
The tank in the cab of my hiboy is rusty and full of god knows what, and I don't think cleaning it will be a viable option. I'd like to keep one in there, because the aftermarket side tank I've got will leak out the fill neck on inclines.
If I can't find a tank, I'll attempt to clean my own. My only concern is that because there is so much crap in the tank, I won't be able to get everything out. I've thought about getting the tank boiled, but then I'd be worried about compromising the structural integrity of the tank. Not good to have a weak tank when it's right behind you driving down the road.
Any help is appreciated!
-Jameson
Old Sep 9, 2013 | 07:26 AM
fmc400's Avatar
fmc400
MSEE
I don't have much useful advice to add to this thread, other than to add another vote for replacement if possible (instead of cleaning). I had trouble finding a shop around here that even understood what I was asking. I found a radiator shop that offered to do it, but it came out filthier than when it went in. This is probably just a function of my area, because most people here drive Priuses or giant SUVs. I would imagine it's less of a hassle in other areas.
Old Sep 9, 2013 | 07:57 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Not a 100% sure, but I think Dennis Carpenter and Blue Oval Truck Parts have new in-cab tanks.
If all else fails, Eastwood has a system that you can buy. It includes stuff to chemically clean the tank, then a coating that you slosh around inside to seal anything that didn't get removed and it also seals small pin holes.
Old Sep 9, 2013 | 08:03 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Just checked, Blue Oval has them for $209.95 they have both without and with evap emission controls.
They are steel. I don't know of anyone making a poly in-cab tank.
Gas Tank - In Cab - 18.5 gallon - w/ evaporative emission system & models w/ 3/8" fuel line - OE Styling
Old Sep 9, 2013 | 01:07 PM
DutchmanAZ's Avatar
DutchmanAZ
I wasn't fond of the idea of a gas tank right behind me, mainly due to the smell and of course the safety factor. Have you considered replacing the rear tank with an aftermarket? That's we we did, and the new tank sits inside the frame rails under the bed. We then put an electric fuel pump in because I got tired of having leaky diaphragms at the most inopportune times...
We removed the in cab tank entirely.
Old Sep 13, 2013 | 02:34 PM
Old Coyote's Avatar
Old Coyote
My brother had the same problem on a '66 he bought. We took a mini-grinder to the seam around the edge of the tank and essentially just split it in half (like opening a clam). Cleaned all the rust and crap out of the inside, put it back together and bronze-wlded the seam.
Old Sep 13, 2013 | 04:18 PM
DutchmanAZ's Avatar
DutchmanAZ
I'd recommend removing the in cab tank. Here's a link why (it's about chebbies, but I think it applies to the fords of the same era as well).
Old Trucks Leave Fiery Legacy, Smoldering Anger | FairWarning
Old Sep 13, 2013 | 04:29 PM
Old Coyote's Avatar
Old Coyote
I agree, and recommended the same thing to my brother, but he went the route I described. And just to add to what Dutchman says, along with that electric pump use the relay that runs off the oil pressure sender so you don't get fuel pumping when the engine's not running.
Old Sep 13, 2013 | 04:32 PM
DutchmanAZ's Avatar
DutchmanAZ
Unfortunately, the replacement tanks (that I could find anyway) fit only behind the rear axle. I'd much rather have it out of the "crumple zone" (do these exist in the old trucks?) ahead of the axle, but still inside the frame.
And yes, Coyote - definitely have the inertia/shut off on the electric pump set up.
Old Sep 13, 2013 | 04:41 PM
jgavac's Avatar
jgavac
I considered getting something along the lines of a fuel cell to put under the bed in the back like 2wd trucks have. I haven't looked into the price of one yet, which would be the major determining factor. I'm not made of money, so I'll most likely clean what I have.
As far as the "crumple zone", you have to figure that if gas tanks in trucks and cars can still be found behind the rear axle/suspension, that there isn't very many cases of the tank exploding or catching fire in a crash. Since most collisions are head-on or side on, behind the rear axle inside the frame is probably the safest area for a tank.
I do have an aftermarket tank on the truck anyways, one that fits between the frame and body like the chevy saddle tanks (which in fact, the exploding tank was written off as an over-exaggeration). It's a poly tank, and I've been running the truck of that for a while. The problem there is the fuel neck leaks on inclines.
Mikeo0o0o0: I swear I checked BOTP before, but I must have missed it. Thanks for the link
-Jameson
Old Sep 13, 2013 | 05:25 PM
mikeo0o0o0's Avatar
mikeo0o0o0
-Jameson
No problems Jameson, glad to help.
Old Oct 15, 2013 | 02:24 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here is what I am looking into for ol blue, better late than never on the link.
MTS COMPANY, L.C. - Ford Pickup fuel tanks
Old Oct 16, 2013 | 10:20 PM
jgavac's Avatar
jgavac
Good find.
Long story short, I pulled the tank out and was all prepped to be cleaning out some nasty rust (I even had acid to clean it with), and I pull the fuel sender out and stick a flashlight in, and lo and behold there was not a single spot of rust or gunk.
So I just cleaned it out with some hot water then prettied up the outside. Blew out all the lines with air. Not sure where all the **** was coming from, but it appears to be gone.
77_f250_custom
May 19, 2015 11:27 PM
F250GH
Dec 13, 2011 11:19 AM
buffaloboy123
Jul 20, 2006 03:20 PM
j gibbs
Apr 26, 2005 05:38 PM
250K AS
Aerostar
Apr 1, 2003 09:42 PM
