Fan shroud?
Old Sep 8, 2013 | 06:16 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Fan shroud?
I was wondering if the upper half of the fan shroud was made to be
cut from the lower half. My fan clutch wires were sheared by the fan blades
Old Sep 8, 2013 | 06:58 PM
big inch's Avatar
big inch
Originally that was the way they were supposed to be removed. There are screw holes that can be used to put the shroud back together if you did want to cut it apart.
Old Sep 8, 2013 | 07:18 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Thanks for confirming my thinking! Do you know if there is a harness from the fan clutch to the engine?
Old Sep 8, 2013 | 07:48 PM
big inch's Avatar
big inch
There is, but it is a part of the main engine harness. Is it not repairable?
Old Sep 8, 2013 | 07:57 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
yes, im going to cut the upper half of the fan shroud, splice/reroute the existing wires
on both ends. I was hoping ford had a pig tail, since so many have been cut!
Old Sep 8, 2013 | 08:02 PM
big inch's Avatar
big inch
It is not common to have damage to the engine side of the harness. I am not sure if the pigtail is available. I have never tried to get one. Maybe someone can chime in on that.
Old Sep 8, 2013 | 09:28 PM
indyraven's Avatar
indyraven
My fan munched the wires coming off of the clutch a few months ago. Didn't really want to buy a $200+ fan clutch, so I ran to Napa, and snagged the shrink tube that has adhesive on the inside of it. Soldered the wires back together, and used the shrinktube to seal my repair, everything works. Just make sure you leave yourself enough slack to be able to stick the wires back up where they belong, or it will pretty quickly get into those wires again. Also, make sure you spend the extra bucks and get the shrink tube that seals, don't try to use tape, or the cheap shrink tube with no adhesive.
Old Sep 8, 2013 | 10:03 PM
BLADE35's Avatar
BLADE35
you guys may want to check the Water pump Shaft for excessive Play
Supposed to be the common cause of those Fan wires Getting Cut
Old Sep 9, 2013 | 07:18 AM
indyraven's Avatar
indyraven
In my case, the wires got munched when the outer shroud got forced into the fan after running over a Subaru.... LOL (Good advice on the water pump tho, I'll remember that!)
Old Sep 9, 2013 | 07:25 AM
2006lariat's Avatar
2006lariat
I went through this in June. In my case, the 2nd alt locked up, and tore the pulley's off the front of the motor, than the belt wrapped around the fan, and ripped the wires off. Getting the shroud out the first time sucked! In total I did it 3X, as I ran it a couple day's till the part's came in.
Old Sep 9, 2013 | 07:35 AM
vloney's Avatar
vloney
Take the top radiator mounts loose, re-route wiring between radiator and upper support, remove top radiator hose, remove vent hose from radiator, remove two screws from top of shroud, pull back on radiator, then the shroud comes out in one piece, no cutting necessary.
Old Sep 9, 2013 | 10:11 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
I soldered new wires, taped them, shrink wrapped them and loomed them Do you think the tie raps will hold out, through the radiator?
Old Sep 9, 2013 | 10:27 PM
BLADE35's Avatar
BLADE35
Iv never seen a wire actually zip tied to the Radiator like this
Old Sep 9, 2013 | 10:37 PM
Yahiko's Avatar
Yahiko
I did find and can look it up that you can get both plugs as pigtails.
I should know I have a set for my fan control project that I put on
the back burner for now. Here is the test box with the plugs.
Sean
Old Sep 10, 2013 | 05:36 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
Im open to better idea's! I think with the suction of the fan you have to secure the wires away from it. I think that's why fords idea was short/straight...
