`95 F150 w/ 5.0L 302 bored .040" crank turned .010" on rods and mains. Mild cam (crane p/n 364112) which gave it flat tappet lifters instead of roller lifters (crane's ***** up, not mine...still saving to fix it). it is a speed density system.
my question is this: will swapping from 19lb injectors to 24lb injectors have good or bad effects? I plan to eventually convert to mass air and know i will have to get a mass air meter tuned to the 24lb injectors, but will putting them in now be beneficial?
