What to do? leaking
Old Sep 6, 2013 | 12:40 PM
ck22's Avatar
ck22
Unhappy What to do? leaking
I went out side today and seen oil on the ground under my truck. I got underneath and noticed a corner screw of the oil pan missing. (front passenger side). But above it I noticed metal plate craked on both sides of corner. I dont know if this is what they call the upper oil pan or a bed plate or something else?[/COLOR] I rigged it using some jb weld putty to stop leak for now. AM I SCREWED? It looks like you would have to have the engine taken out to have it fixed.
Anyone know what that may be? Am I going to have to sell one of my kids to be able to pay for this repair? LOL! Anyone have any answers or suggestions?
Old Sep 6, 2013 | 02:22 PM
Bonanza35's Avatar
Bonanza35
Wish I could help, but I can't. I do feel your pain. Someone should check in soon and be able to help you out.
Old Sep 6, 2013 | 03:31 PM
BLADE35's Avatar
BLADE35
If its missing a Oil Pan Screw just put one in
Do you have a Pic of the cracks
Old Sep 6, 2013 | 04:53 PM
npccpartsman's Avatar
npccpartsman
I think you should be able to do the upper oil pan in frame. It's a bit of a job to get the lower oil pan and pick up tube off but after that there's 9 small bolts that hold the upper oil pan (I always called it a windage tray) to the bedplate. I just scrapped the one from my old motor this morning. Bummer.
Old Sep 6, 2013 | 05:13 PM
69cj's Avatar
69cj
With out seeing it, if the bolt fell out one should be able to put one back in.
Old Sep 7, 2013 | 02:46 PM
ck22's Avatar
ck22
thaks guys, i'm not concerned about the screw, I just put another one in. The problem was thr cracks in the upper oil pan i guess made it lose its seal and leaks. I had to rig it until I get a real repair. I just put jb weld putty on it that stopped the leak, but need a real fix. Thanks again
Old Sep 7, 2013 | 03:04 PM
big inch's Avatar
big inch
It sounds like you are describing the bed plate. I have only seen one crack, and that was because of the broken rod that was trying to get out.
Can you post some pics of the area in question?
Old Sep 7, 2013 | 05:31 PM
m-chan68's Avatar
m-chan68
I won't comment until I see a very clear picture posted of the casualty.
CodyJames
Jun 30, 2017 10:17 AM
donmartin13
Jun 3, 2008 10:52 AM
PSD350
Apr 22, 2007 07:00 PM
dieselfitter
Apr 14, 2006 08:28 AM
