2002 Superduty
Old Sep 5, 2013 | 08:06 AM
Haoleman's Avatar
Haoleman
2002 Superduty
I have about 100,000 miles on the truck and need to change the antifreeze. I've tested it yearly and it's ok but it's time. Should I change hoses too and which ones ? They seem fine but I know appearance is deceiving. It has yellow antifreeze from the factory and hoses are original. Factory hoses or what brand? I have had issues in the past with non factory hoses being the same diameter and fit. What should I use?
Thanks!!!
Old Sep 5, 2013 | 10:01 PM
DND58's Avatar
DND58
It's time to get that stuff out of there. The attached link is long, but contains a lot of good info, as well as some part numbers and such. Others will be along also.
I went with G-05(same as factory gold) as at the time, ELC as mentioned in the link was difficult to find. I would replace thermostat and housing, as well as hoses at the least.
https://www.ford-trucks.com/forums/9...formation.html
Around 100K miles is kind of a maintenance milestone. I've also attached a link to a failure prevention thread thats loaded with good stuff.
https://www.ford-trucks.com/forums/1...on-thread.html
Good Luck!
Old Sep 5, 2013 | 11:04 PM
crop harvester's Avatar
crop harvester
you can buy upper & lower Motercraft radiator hoses at rock auto,I think your going to have to go with ford part store for other OEM hoses.check out site venders at top of this page for ford parts store.
pa.sales
1961 - 1963 F100 Unibody
Jul 17, 2018 09:01 AM
skuteman
Sep 10, 2005 10:56 AM
skuteman
Feb 22, 2005 10:33 PM
hd4us
Apr 10, 2004 10:34 AM
redvet
Jul 27, 2003 10:34 PM
