Sponsored by: Real Truck
Need some help!
Old Sep 6, 2013 | 11:49 AM
EbonyandIvory's Avatar
EbonyandIvory
I forgot to write them down to check them and none as come back. Would mass air cause this?
Old Sep 6, 2013 | 12:29 PM
99f350sd's Avatar
99f350sd
Mass air controls the fuel into the engine so yes...usually clean it first then see if you can try one B4 buying..
Old Sep 6, 2013 | 08:28 PM
EbonyandIvory
Well unpluged it seems to work better I cleaned it but havnt tried it yet. Are the 4.6's the same? Like cars and trucks??
Old Sep 8, 2013 | 11:59 AM
EbonyandIvory
So I cleaned it and it now doesn't fall on its face but still has a miss right at the start of the throttle hit and randomly other times.
Old Sep 14, 2013 | 12:57 PM
EbonyandIvory
So if anybody is out there still, I have few more questions. Would t be a good idea to purches the msd coil set? And what plugs should I run with them?
Old Sep 14, 2013 | 12:59 PM
99f350sd's Avatar
99f350sd
Motorcraft plugs and just replace a coil if its bad..IMO
Old Sep 14, 2013 | 04:38 PM
EbonyandIvory
Yeah but by the time I pay to have the coil that's bad foundd I could replace them all. Dose that makes sense? And should I run iridum??
Old Sep 14, 2013 | 04:48 PM
redford's Avatar
redford
FTE Leadership Emeritus
No, use Motorcraft Platinum plugs.
Old Sep 14, 2013 | 04:53 PM
EbonyandIvory
Isn't iridum better?
Old Sep 14, 2013 | 05:08 PM
redford's Avatar
redford
Not in the Modular engines.
Old Sep 14, 2013 | 05:54 PM
EbonyandIvory
Ok thanks guys
Old Sep 15, 2013 | 10:37 PM
EbonyandIvory
So found out today that the truck wont rev past 3500 rpm. any ideas what might cause that?
Pumpoperator6
Apr 25, 2017 10:45 AM
justin richter
Modular V10 (6.8l)
Mar 23, 2017 04:35 AM
89 superduty
May 10, 2011 08:53 PM
Ron Sallee
Jan 7, 2011 01:22 AM
mackdog
Jun 13, 2008 02:06 PM
