1999 5.4L feel weak?
Old Sep 3, 2013 | 11:56 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
It in 99 Expedition eddie bauier. Bought at 157K back in March 3 Now it had 179,700 miles.
What I have done to it.
New exhaust manifold on passenger side. #1 had big hole it rot out.
New spark plugs/ boots
Thermostat. Old one was open at 173oF
air filter
flush coolant it was NASTY
vacuum hoses
Fuel injectors
Fuel filter
Mileage was used to be 17-19 but now it just downhill to 13-15. I ever clean MAF and put new air filter.
Engine seem to having issue with power lately. It doesn't had peppy at high rpm it just rev way high it struggling.
It had miss at random times sometime it ran so smooth then other time it just shake very tiny like every-time cylinder fire it stumble.
No engine light on. Plan test sensors tomorrow with AE scanner to find out.
Old Sep 10, 2013 | 10:01 PM
RBlac's Avatar
RBlac
Well did you find anything with the AE Scanner?
Old Sep 10, 2013 | 10:30 PM
Milwaukee1979F150
Haven't see anything. That reason I came on here to ask what to check on this one?
Right it had 180,040 but mileage been average 14-15. It used to get 16 in same condition.
Old Sep 11, 2013 | 10:54 AM
RBlac's Avatar
RBlac
So no codes at all then? It could be EGR stuck open that causes poor top end performance, and/or something with the exhaust system, clogged or failing cat etc.. O2 sensor?
Not exactly sure without more info.
Old Sep 11, 2013 | 11:44 AM
tomfiii's Avatar
tomfiii
It may be worthwhile to go to dealer and have them use breakout box to narrow down problem.
Old Sep 11, 2013 | 08:08 PM
Milwaukee1979F150
When I bought it was average 13. Bad thermostat open at 170oF.
Passenger exhaust manifold had giant hole on #1 port so I think valves burnt but it just randomly idle smooth/rough after 20K miles same thing. I replaced that manifold it was PITA job.
New spark plugs/ coil boots same issue it had tiny miss.
EGR Valve work good I test.
I think cat convertors could be plugged I will need get laser thermometer to find out what temp.
Old Sep 11, 2013 | 09:21 PM
kbsupercrew's Avatar
kbsupercrew
My 2000 f150 5.4 was getting bad gas mileage and I didnt bother looking for it until I had a drop in rpm sitting a the light, changed the Aftermarket Iac I put in 6 months ago (BWD), with motorcraft and not only did it fix my idle drop, but fixed my bad gas mileage, win win., just my experience
Old Sep 11, 2013 | 09:23 PM
Milwaukee1979F150
I did check IAC back in March or April try solve rough cold idle it never cure.
I would love to buy smoke machine so I can find if there vacuum leak on this one.
Old Sep 11, 2013 | 09:59 PM
kbsupercrew
Rough cold idle is usually intake gaskets
Old Sep 11, 2013 | 10:25 PM
Milwaukee1979F150
YIKE I hope it not. It just PITA to do in Expedition. I rather do on superduty.
Going need smoke machine to confirmed if it intake gasket.
Southers0423
Jul 1, 2014 06:09 AM
cjsdad1
Jul 13, 2013 08:36 AM
bulldogchief
1983 - 2012 Ranger & B-Series
Jan 4, 2011 07:51 PM
jarch
Oct 18, 2005 03:43 PM
seth1
Dec 15, 2004 07:31 PM
