Cruise deactivation switch harness fuse?
Old 09-03-2013, 06:11 PM
sccamper's Avatar
sccamper
sccamper is offline
I finally got around to trying to fix my inop cruise control. Did the self test and got a flash code 2, BPP switch. I replaced the switch but its still inop and still have flash code 2. Got my meter out and started checking system. I found the fuse in the deactivation switch recall harness was bad. I removed the harness and plugged the two remaining connectors together and the cruise works. I returned home and unplugged so it wouldnt short out. The connectors are clean and no signs of fluid.
Says on jumper harness that the fuse isnt serviceable and to replace with 9F924 harness. Well the fuse is serviceable and the harness ohms out good. Is there a need to buy a new harness or would I be ok with a new 5 amp fuse? Anyone else replaced just the fuse? Did it blow again? Thanks
Old 09-03-2013, 07:42 PM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
This was part of a recall, ford replaced the one on my 02 Ex for free sometime in 2011. It's worth a try, just my .02
Old 09-04-2013, 07:01 PM
sccamper's Avatar
sccamper
sccamper is offline
I talked to a friend that works in parts at dealer. He said the harness kit was a one time recall, the part comes with 12/12 warranty. The recall had been done long before I bought the Ex. The new harness and switch is only $20. But I put a new fuse in the "non-serviceable" fuse holder. The cruise worked today, for the whole 2 minutes I had a chance to use it. If it pops another fuse I get a new kit.
Old 10-22-2013, 07:05 PM
TC PSD Excursion's Avatar
TC PSD Excursion
TC PSD Excursion is offline
does anyone know if they will still do the recall? im fairly sure mine has never been done.
Old 12-23-2013, 09:38 AM
Metrojd's Avatar
Metrojd
Metrojd is offline
Im having the same trouble.
Talked to a Tech friend @ the local Ford Dealership, Gave him my Vin and he said on my 2000 there were no open recalls on it.
So basically Im on my own as far as replacing the switch.
Old 12-23-2013, 10:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,634 Likes on 1,097 Posts
Recalls are good forever.
Not all notices are recalls, but this one is. You can tell if it is a real recall by the number. If it has an S (Safety) or an E (Emissions) then it is a recall and never expires.
There are also Customer Satisfaction Programs that will have an A or a B. These are NOT recalls and may have an expiration.
Old 12-23-2013, 12:45 PM
1 Excursion camper's Avatar
1 Excursion camper
1 Excursion camper is offline
A recall is lifetime.! if it says you cannot replace the fuse then take it in and tell them the fuse is blown. I don`t even think they will sell you a recall P/N over the counter.
Now off the record, if the harness is OK and it just needs a fuse then replace it, and move on.
Old 12-23-2013, 04:39 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I had a dealership tell me that it was not back when this came up.
Was that a case of them not getting paid after a time limit had expired
of there service manager just full of BS?
Sean
Old 12-23-2013, 04:48 PM
Metrojd's Avatar
Metrojd
Metrojd is offline
Thumbs up
Picked up the kit. #1L1Z 9F924 AA list for $26.33.
Pulled the old switch out , installed the new one,
Brake cleaned the connector, installed the connector wire and I'm in bussiness....
The Cruise Works....
Old 12-23-2013, 06:59 PM
Mark Kovalsky
Sean
The ALWAYS have to do a recall. The dealer will get paid for it whenever they do it, even if it is years later.
Old 12-23-2013, 08:32 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Thank Mark, That is good to know.
Have a Merry Christmas.
Sean
Old 09-23-2017, 04:19 PM
MichelleP's Avatar
MichelleP
MichelleP is offline
I have 2002 f150 I had the recall done several years ago. Now my switch is leaking and the harness plug is soaked in fluid. I got the sw3650 repair kit from ford. While I was there they said the new harness included with the switch was all I need. Instructed me to unplug the entire long, fused, harnness and plug this one in its place. Is this new adapter fused? I am questing it because all the videos show this new harness as a switch adapter and plugs into current harness.????????????
Old 09-23-2017, 06:11 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Yes.
I dunno, maybe the videos were posted by people who didn't know what they were talking about. Seems pretty common on u-tube.
Faded_Memories
1999 to 2016 Super Duty
06-28-2019 08:19 AM
Daneman
04-25-2019 02:01 PM
tractoman
07-14-2014 10:21 PM
jamesblonde82
06-16-2009 09:34 AM
grousedog
1997 - 2003 F150
08-29-2007 05:51 AM
Quick Reply: Cruise deactivation switch harness fuse?
