diff. oil
Old Jun 16, 2003 | 07:57 PM
treb's Avatar
treb
diff. oil
hi yall treb here. always lot of questions. 99 ranger man. says nothing of change rear diff. oil seems to me its got to go bad sometime really can not figure what to do about it. man. say only if water in it or for repairs. 99ranger 2.5 5 manuel 53k thanks for any help. treb maintance freak. in fl.
Old Jun 16, 2003 | 08:29 PM
saintthomas's Avatar
saintthomas
diff. oil
Hey treb,
The trusty old Haynes manual says that you should change it every 30,000 miles. More often if you do 4 wheelin. And also you should change it anytime you drive through high water. It's not so much that it goes bad per say. More actually that it collects junk and fine particals from the gears
Old Jun 17, 2003 | 02:30 PM
treb's Avatar
treb
diff. oil
thanks Saintthomas for info, makes lot of sense to me. i recon if no drain plug will have take cover off or loose? which or what is best way to drain it? i know just enough to get self in trouble at times. treb
Old Jun 17, 2003 | 03:53 PM
superrangerman2002's Avatar
superrangerman2002
diff. oil
Two ways to get old oil out.
1. with a suction gun, sticking hose down into diff through the fill hole. You wont get it all this way maybe 85% of it.
2. (best) Remove diff cover, scrape old rtv seal off both diff and cover, and re-apply with new rtv sealant, then fill diff with new stuff.
Old Jun 17, 2003 | 04:23 PM
treb's Avatar
treb
diff. oil
thanks supperrangerman2002 on change diff. oil recon i will get to it treb yall take now
Old Jun 19, 2003 | 09:22 PM
saintthomas
diff. oil
I agree with superranger man about your options. Make sure you have a lot of rags. Wear clothes that you don't mind getting nasty. The smell from that differential oil takes forever to wash out. Also when you pull the bolts, start at the bottom and work up. Leaving the top three in to hold the cover on. You can loosen them. But don't remove them. Have fun.
Old Jun 20, 2003 | 04:59 AM
treb's Avatar
treb
diff. oil
thanks again saintthomas 80w90 has its own smell may go fishing first
