I have got the EVTM on disc, but you have not given me enough info. I looked up C3136, and it must have a lot of wires in it, because about a dozen different circuits came up associated with this connector.
In the index listing, 124-1 is the power mirror circuits. But 124-1 did not come up in the c3136 list.
What's wrong? Brown wires are usually the running lights circuit, but it could be something else also.
Well I found the blown fuse--it was the Central Junction Box (in cabin) #39, 40 or 41 which are supposedly not used or for modified vehicles only. Changed the blown fuse, added two in the vacant slots, all 30a.
I'd tapped into a rear blower assembly always hot connector for use to power my alarm. It seems the above-mentioned fuses control the circuit I couldn't find---all is well now.
