Sponsored by: Real Truck
Do I need new rotors?
Old Aug 31, 2013 | 10:56 PM
jerrymlr1's Avatar
jerrymlr1
So I have a 2006 F350 CC diesel w/148k miles. I have never had the brakes worked on or have had any problems with them. I am having the brakes done tomorrow and the mechanic says that I should get new rotors without even looking at the brakes. Is this true or should they be at least looked at. I searched the forums and seen that some have had the same rotors for quite a while. Anyway thanks for any advice.
Old Aug 31, 2013 | 11:10 PM
Hotpocket's Avatar
Hotpocket
if they are stock at 148k miles, yes you need new rotors
Old Aug 31, 2013 | 11:17 PM
jerrymlr1's Avatar
jerrymlr1
Yes stock. Any brands better than others?
Old Aug 31, 2013 | 11:20 PM
Hotpocket's Avatar
Hotpocket
i bought some raybestos rotors from RockAuto Parts Catalog and they are awesome
Old Aug 31, 2013 | 11:26 PM
Shake-N-Bake's Avatar
Shake-N-Bake
My front rotors lasted over 250k miles before I changed them. My original rear rotors are still on my truck (314k miles). If you changed your pads before they wear out and dont overheat your brakes then your rotors should last a very long time.
Old Aug 31, 2013 | 11:30 PM
Hotpocket's Avatar
Hotpocket
i am on my 3rd set of rotors due to warpage, cause i tow alot and if you turn them there is almost no material left
Old Aug 31, 2013 | 11:34 PM
jerrymlr1's Avatar
jerrymlr1
Well........
Old Aug 31, 2013 | 11:37 PM
jerrymlr1's Avatar
jerrymlr1
Well, that confirms what I've read on other threads but slightly contrary to what Alan says.............. Most of the miles I've put on have been highway miles so that helps. I've never heated them up either. Guess we'll have a look tomorrow. I don't mind spending the money but don't want to just blow it either.
Old Aug 31, 2013 | 11:41 PM
Hotpocket's Avatar
Hotpocket
see what the people say that are turning them...i tow 50% more then what my truck is rated for
Old Aug 31, 2013 | 11:43 PM
Hotpocket's Avatar
Hotpocket
i turn them once then replace after that
Old Aug 31, 2013 | 11:52 PM
dkf's Avatar
dkf
If they are original rotors that have never been turned, without warpage with no deep grooves they could be turned.
I got around 60k out of my OE rotors. The rust got to them, started flaking too bad so they would not pass inspection.
Old Sep 1, 2013 | 12:09 AM
Shake-N-Bake
There is no reason to turn the rotors unless they are worn unevengly. I have never turned my rotors on my truck because that only makes it easier for them to warp. The only reason I replaced my front rotors was because they were getting close to the minumum thickness. My trailer weighs 16,500lbs so the truck does work pretty hard from time to time.
Old Sep 1, 2013 | 12:13 AM
Shake-N-Bake
I didn't think of that.....rust would be good reason to replace those things. I guess I am not used to dealing with that issue.
Old Sep 1, 2013 | 12:27 AM
dkf's Avatar
dkf
Down south and in the desert it is easy to forget the perils of rust. Trying to keep rust at bay is a never ending process if you care about what your truck looks like up north. I never bother having rotors turned but some shops due it because some people want to go out the door as cheap as possible. I agree the extra rotor thickness is an asset.
Old Sep 1, 2013 | 01:13 AM
EXv10's Avatar
EXv10
You mean N.E. They don't have salt in the N.W.
