Performance chip
The 1715 tuner is probably your best bet - no permanent modifications, all the benefits of the chip, You can tweak any number of trucks (all your friends will be lining up at your door!) and you get a code scanner to boot.
Can't beat that!
XXL
Can't beat that!
XXL
Performance chip
Sorta!
You can install and remove the "program" any time you wish and then install on another vehicle, BUT you cannot install the program on an unlimited # of vehicles at one time. In other words, once the program is installed on a particular vehicle, all the tuner can be used for is code reading on other vehicles.
Performance chip
I have a exhaust and intake on my truck, and I am getting horrible gas mileage 8-9mpg. Before I put the intake and exhaust on I was getting like 13mpg. Would the superchip help the mpg? Thanks
Performance chip
I don't know how you lost 35% of you mileage by adding what you did (is your foot heavier now?), but a chip won't get it back to where you started. I noticed .5 mpg increase.
Performance chip
Actually, based on the numbers we ship, most people do not prefer the Microtuner. Its 50/50. A tuner is great if the only modifications you intend are intakes, exhausts and tire size changes. If plan to do more than a Microtuner won't do the job (it can't be custom coded). Plus Diablo tends to have a bit more power. Both products are great and each has its uses.
