Fly Wheel Identification
Old Aug 29, 2013 | 06:21 PM
mikesvintagecars's Avatar
mikesvintagecars
Hello trying to find out what fly wheel i have stamped C5AE-6384-AH
Any help would be appreciated Thank You
Old Aug 29, 2013 | 06:50 PM
JEFFFAFA's Avatar
JEFFFAFA
6384 is a flywheel ring gear. Is there any numbers on the flywheel?
Old Aug 29, 2013 | 07:12 PM
mikesvintagecars
The #s i gave are stamped on the fly wheel nothing else??
Old Aug 29, 2013 | 07:21 PM
JEFFFAFA's Avatar
JEFFFAFA
Are you sure it says 6384 not 6380? Is this a manual transmission "flywheel" or a automatic's "flex plate" ?
Old Aug 29, 2013 | 08:02 PM
mikesvintagecars
Yes it is plainly stamped with those #s. 11 inch clutch. It was supposed to be for a 390, but not having any luck with the #s.
Old Aug 30, 2013 | 09:20 AM
Freightrain's Avatar
Freightrain
Can you post a picture? If you are just trying to figure out if it's an FE, that should be easy enough. The mounting bolt circle is quite large compare to a small block.
Old Aug 30, 2013 | 10:43 AM
JEFFFAFA's Avatar
JEFFFAFA
It is probably one of these.
C5AZ6375K....Engineering # C5AE6380J 12 3/8" Clutch bolt circle
or
C5AZ6375L....Engineering # C5AE6380K 12 7/8" Clutch bolt circle
Old Aug 30, 2013 | 05:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
On sale day, 352/360's magically become 390's! 390's have a 3.78" stroke, 352/360's have a 3.50" stroke.
M/T: 1958/64 FE engines have a 153 tooth flywheel ring gear, 1965/76 FE engines have a 184 tooth flywheel ring gear.
C5AZ-6375-K .. 352/360 Flywheel ~ Use with 11" clutch on a 12 3/8" bolt circle.
1965/67 F100/350 352 / 1968/76 F100/350 360 / 1965/67 Galaxie/LTD 352.
C5AZ-6375-L .. 390 Flywheel ~ Use with 11 1/2" clutch on a 12 7/8" bolt circle.
1968/76 F100/350 390 / 1965/71 390 Passenger Cars.
C5AZ-6384-A .. Flywheel Ring Gear-184T ~ Use with either C5AZ-6375-K or C5AZ-6375-L flywheels.
Old Aug 31, 2013 | 09:32 AM
mikesvintagecars
Wink Thanks
Thank You for the Info, i wil mark it as a 360 not 390, The #s game !!!!
Old Aug 31, 2013 | 09:48 AM
mikesvintagecars
360 Ford
Yes it has the 184 Teeth so the 65/76 Year. Thanks again.........Mike I will put it on the shelf for sale.
twr71
Dec 31, 2010 04:39 PM
smbikes
May 5, 2009 12:39 AM
BlueovalFE
Mar 30, 2009 10:16 AM
toolebox1
Nov 9, 2004 09:09 PM
74rusto
Apr 20, 2004 03:05 PM
