302 mpg problems
Old Sep 2, 2013 | 01:41 PM
CaptCameltoe's Avatar
CaptCameltoe
I still say save yourself a lot of time and hassle and go back to stock intake and proper 2bbl carb or try a much smaller 4bbl carb. You say the mpg and power was worse with the stock 2bbl, was it good or was it screwed up in some way? That 8.0-1 comp motor stock has between 120-140 hp at around 3600 rpm, headers I guess might make a 5-10 hp/5-15 ft lb tq difference somewhere in the rpm range, but not a lot to really make much of a difference. As blue and white said obvious places to start are spark plug condition. carb tunin/timin are a given to get this truck where it should be mpg wise. Does the truck belch out black smoke or is the exhaust sooty? I'd really like to see you get this truck gettin the gas mileage it should, because I think there's a lot left on the table. gas is way too expensive to waste much for very long
lonerangermotors
Oct 13, 2012 04:57 PM
Cody_302
33
May 11, 2012 09:35 AM
cray0971
18
Aug 28, 2011 08:03 AM
pac_302_xlt
Dec 1, 2005 01:30 AM
highrider76
May 24, 2004 11:46 PM
