Sub box installs,suggestions
Old Aug 26, 2013 | 10:02 PM
remhaust's Avatar
remhaust
Hey guys been looking and looking and of course best box would be to make to speaker and vehicle but just wondering what sum of you did or have and placement.Not enough room it seems for good box behind seats(crew cab) without the use of shallow mount subs.And if everyones using shallow mount subs which and how do you like.My original thought was to make a box and have it sitting right behind center counsel and if I needed the extra room just unhook 2 wires and bam,you got room and would only take a second and would have the best sounding bass and you could use better subs?Any thoughts,ideas or comments
Old Aug 26, 2013 | 10:09 PM
gsxr1300's Avatar
gsxr1300
I have this box
2008superduty
Old Aug 26, 2013 | 10:47 PM
ngng's Avatar
ngng
When I have more time I'm going to build a box behind the rear seats for a single, shallow mount 13" JL. I bought my truck for utility and passengers and am not willing to compromise. I considered mounting a sub in the center console, but it's going to rattle like none other, and I lose that storage.
Old Aug 27, 2013 | 01:02 AM
Dim Sum's Avatar
Dim Sum
I have a JL stealthbox sitting in a closet. The sub is great as I had it in my 2010. I want it in my 2011, but am reluctant to lose the under seat storage.
Old Aug 27, 2013 | 05:46 AM
ruschejj's Avatar
ruschejj
I built enclosures for behind the rear seats and have two kicker comp 10" boomers.
It is possible but I found that you have to cut away the carpet and insulation on the rear wall of the cab to do it. Doing so gains an inch which is enough to use normal speakers and have a big enough box for them to sound good.
Passenger side is a standard wedge shape, driver side is an L shaped wedge to both avoid the power rear window motor and also gain internal air volume for a decent sounding box.
Both mine are sealed, amp is installed under the driver side rear seat. I also used two line level converters to feed the amp, left and right, rear channel only. This works well for listening to talk radio...
Old Aug 27, 2013 | 06:00 AM
2000silverbullet's Avatar
2000silverbullet
Originally Posted by gsxr1300
I have this box
2008superduty
Same here.
The rest of my components are in my sig. No complaints at all.
Old Aug 27, 2013 | 11:27 AM
B&LLandscaping's Avatar
B&LLandscaping
I installed one of these -
Car Audio - Subwoofer Systems - MircoSub
matched to one of these -
Car Audio - Amplifiers - JX »
They both fit behind the seat of my crew cab. It's tight, and you give up a bit of space on one side, but it's clean and simple.
I'm not an audiophile by any means, but believe the reviews on this sub, it's amazing.
Old Aug 27, 2013 | 01:10 PM
remhaust's Avatar
remhaust
I wanted same type but seems that still not enough mounting depth unless u use shallow subs.Im no expert but do sum audio stuff and most boxes(good ones) are built for the sub. Meaning if u build for speaker it's so much better sounding then just throwing a sub in a box. But at the same time gotta probably make sum sacrifices to fit behind seat. I will do sum more checking but most of the speakers I looked at were to deep yet
Old Aug 27, 2013 | 01:41 PM
darren32's Avatar
darren32
I know that 2 - 10" Hertz ES250 subs fit in a bassworx F250C210B box with no issues.
I also know they would sound better if they were in a properly sized box but it is what is is. They still sound good.
http://www.bassworx.com/images/enclosures/F250C210B.jpg
Old Aug 27, 2013 | 01:54 PM
SavageNFS's Avatar
SavageNFS
do you have the power rear slider? If you do, please send me a pic with that installed.
Old Aug 27, 2013 | 01:59 PM
darren32's Avatar
darren32
Yes I have the power rear window, here is a pic. You have to take the seat out to get the box in.
Old Aug 27, 2013 | 02:20 PM
ngng's Avatar
ngng
What's the total volume for that? Doesn't seem like enough for two woofers! Where'd you mount your amp? I was thinking of building a box like you have, but adding notches to mount the amps on the woofer box.
Old Aug 27, 2013 | 02:23 PM
remhaust's Avatar
remhaust
decisions,decisions,decisions
O and off topic but I think I have radiator leak,came home from work and saw a puddle under bumper hav not checked yet, but I saw it there when I left 2 weeks ago.
Old Aug 27, 2013 | 02:28 PM
darren32's Avatar
darren32
0.8 cu.ft.
Amps are under the rear pass seat 2 x HDP4. 1,000W to drive the 2 subs and 1,000W to drive the components
LCQ-1 under the front center jump seat
Old Aug 27, 2013 | 03:07 PM
SavageNFS's Avatar
SavageNFS
wow...that looks interesting Darren. Thanks for sharing
