locking hubs
Old Aug 27, 2013 | 08:16 PM
Jarryd's Avatar
Jarryd
I never did figure out how much lift I could expect over my current setup putting in a stock d44 setup. I know with a stock ttb setup I could expect it to sit about identical to now and I would expect the sas to leave it higher than that, possibly high enough to fit 35s.
Old Aug 27, 2013 | 08:23 PM
GNR22's Avatar
GNR22
You end up taller with the SAS than stock TTB. I couldn't tell you how much taller though for certain.
Old Aug 27, 2013 | 08:28 PM
scott79's Avatar
scott79
Hey Jarryd, I might have a d44 available shortly. It's in a 79 F150, all worked perfect when I parked it a couple of years back. PM me if you have any interest.
Old Aug 27, 2013 | 08:58 PM
Big_Red_Brute's Avatar
Big_Red_Brute
You will have to go at least 6" to clear a D44SA. Any lower and the diff will hit the TTB crossmember. Also DO NOT cut the crossmember to clear anything. Doing so will weaken it and cause it to crack later on. Jeffs Bronco Graveyard sells a track bar for an SAS that bolts to the TTB crossmember so you won't have to cut it to clear.
Old Aug 27, 2013 | 09:01 PM
Jarryd's Avatar
Jarryd
I knew it would be taller, it's just hard to say because most people end up doing an additional lift on top of that and have to do shackle flips and taller leaves and blocks out back. I'm just wondering ahead of time so I'll know what is going to take to bring the back up to match, probably an add a leaf and a 2" block would be more than adequate.
Old Aug 27, 2013 | 09:03 PM
Jarryd's Avatar
Jarryd
I thought I could bolt in a stock sas setup and be fine. Didn't know I needed additional lift.
Old Aug 27, 2013 | 09:22 PM
Big_Red_Brute
No, a D44SA will not bolt up under a TTB truck. Allot of modification is required.
Old Aug 27, 2013 | 09:44 PM
Encho's Avatar
Encho
The Southernmost Mod
There is no need to replace the TTB setup and you need the truck ready for the winter, get a TTB, which works just great, and if you decide to plan for next year, just a suggestion, did you check my other thread?.
Old Aug 27, 2013 | 09:51 PM
Jarryd's Avatar
Jarryd
Yea now that I'm researching more, it looks like I'd be into it way more than I had intended. I thought it was a bolt in and go type deal. I think I'll end up going ttb after reading all I just did because the sas will have me sitting way too high for what I need and make it hard to deal with as a dd. I think a ttb setup with 2" lift coils will put me about 2-3" higher than now and still pull me through where I need it to while costing about 1/10 as much.
Do the 2x4 and 4x4 radius arms and tie rods interchange? I know there's a 90 f150 at the junk yard with a complete ttb setup as well as the tranny and everything else. I need to know what all too grab when I go to pick it apart.
Old Aug 27, 2013 | 09:53 PM
Jarryd's Avatar
Jarryd
I haven't checked it yet,I'm on mobile and sigs don't show up on here.
Old Aug 27, 2013 | 09:54 PM
Encho's Avatar
Encho
I posted the link on the first page of the thread, here it is again: https://www.ford-trucks.com/forums/1...l#post11243835
Old Aug 27, 2013 | 10:16 PM
Jarryd's Avatar
Jarryd
Nice link. Definitely looks like stuff I can handle. I'm hoping I can grab this stuff and get it all together pretty quickly. It should be pretty easy add long as I have everything there and ready to go.
joegeds
21
Jul 5, 2013 08:32 PM
p12483
6.7L Power Stroke Diesel
Sep 30, 2011 10:21 PM
pfb
Mar 1, 2007 11:08 AM
brittfan
Mar 16, 2004 07:45 AM
brmann
Aug 14, 2001 08:16 AM
