Help with TDC Flathead 6
Old Aug 27, 2013 | 02:10 PM
AXracer's Avatar
AXracer
Suggestion: stop trying to shortcut, second guess or circumvent the proper procedure. Old Dan gave you the process in post #13, follow it exactly and you will be good to go, Matching up your engine to a picture of someone else's engine will not work unless your distributor was installed exactly like theirs (1/12 or 8.3% chance that's the case).
Old Aug 27, 2013 | 02:30 PM
brain75's Avatar
brain75
Just to be clear I am not saying install it so your rotor is pointed at 10 or 11 o clock as mine is. I am saying install it so your rotor is pointed at the casting seam - exactly 90 degrees from the retention clips when the crank #1 is at TDC (timing mark on timing indicator). Since the distributor and cap are both keyed with a notch that better line up with #1 on everyone's rig not just mine.
Old Aug 27, 2013 | 04:20 PM
Flathead ford's Avatar
Flathead ford
Ax racer
I'm not short cutting been working on this flathead for a month so c your way out if you give those worthless comments. Brain 75 mine was reset last night it was 180 out. Thx for the comment though
Old Aug 27, 2013 | 04:37 PM
brain75's Avatar
brain75
I understand the frustration of not being able to use the search, pm, groping for answers here...... and especially having all the right pieces parts assembled correctly, knowing it is together right and still not working. Ya got to understand one of our frustrations, we answer (almost) the same question 3 times a week it feels like... and a lot of the guys asking for help seem to get excited and shortcut things.
2 more posts and you can use the search feature
Ax is a very knowledgeable guy and an asset to this board (not to mention a lot more active than I and a lot better body man than I) so everybody deep breath relax and lets get this guy's motor to purr
Let us know if she is catching and trying, if she has anything else to share and yes - as many have suggested pix - we might eyeball something in the pic that you might not be seeing.
(easiest way for pix is photobucket btw)
Old Aug 27, 2013 | 05:29 PM
brain75's Avatar
brain75
every 226 distributor cap I have seen had the numbers on em, and with the notch key you can't put the cap on 180 off so I'll ask the dumb question - under the grit and grime are there numbers under there?
Old Sep 18, 2013 | 02:22 PM
brain75's Avatar
brain75
did you get it to start?
JamesJ4
Apr 12, 2025 10:22 PM
hharris8
67
Aug 16, 2016 05:24 PM
Thornido
Sep 10, 2008 06:51 AM
Shredit
Jun 24, 2004 07:05 PM
jwxb41b
Apr 11, 2002 09:12 PM
