New Distributor installed, not marked.
It's been about a month between pulling the broken dizzy and installing the new dizzy. Damned if I didn't forget to transfer the orientation from the old dizzy to the new one.
I got the engine set to top dead center just fine, but she won't fire up, she only knocks.
Does anybody know how I go about finding out where to orient the dizzy when I drop it in?
Thanks.
1995 I6 300 TFI
and it will drop into the oil pump drive hex. I usually use the fan or a wrench on the crank bolt to do this as if you try by yourself with the starter the distributor may jump
out of time. Hope this helps. kotzy
I found a notch on the crankshaft pulley, thought that was the timing, set it to TDC on the timing marks and hoped the piston was truly at TDC. Set the dizzy in just so that it was seated all the way. I figured I'd have to experiment till I got it right.
Second time. I actually tried to get the piston to TDC by feeling for compression, couldn't feel any, but I could shine a light into plug hole #1 to see the piston come all the way up. Turns out the notch wasn't anywhere near the timing marks. I couldn't find any other marks on the crankshaft so I painted my own. Nothing. Wouldn't fire, some knocking, however this time I has set the dizzy rotor toward plug wire #1.
Third time. Realized I HAD found TDC, but it was the exhaust stroke. DUH!
Turned the motor another revolution, visually confirmed TDC looking through the plug hole, dropped the dizzy in, rotor towards #1 and it fired up!!
Thought I had it. I drove to Autozone to buy some wiper blades. That's where it overheated and wouldn't restart. While I was waiting around for someone to bring me my tools I poked around and finally found the timing mark on the crankshaft. A tiny line on the wide edge of the pulley. My mark was about 20 degrees off, I scratched that mark off. I bought a 15/16" socket finally, to move the crankshaft bolt with (the crescent wrench was a pain to use).
It started up after it cooled off, so I got my truck home.
And the fourth attempt will be in the morning. I found the true mark on the crankshaft pulley, my timing marks are only on the passenger side, and I know to find TDC on the compression stroke.
I'm learning lots about dropping in the distributor and setting the timing.
Sorry if this post is sort of long. I spend a lot of time searching posts when I need help and I hope my problem can help someone else doing this for the first time.
fordtrucks.com is THE best automotive forum around. I really appreciate everyone on this site and all the help they give out. Thanks.
Hopefully I'll have only one more post left in this thread to tell you my problem is solved once and for all.
http://images.ford-trucks.com/forums...s2/compute.gif
