Please Help Me ?
Old Aug 26, 2013 | 12:07 PM
NewFordUser's Avatar
NewFordUser
Fuel Level Is Always Over 3/4 Of A Tank .
Old Aug 26, 2013 | 12:28 PM
Shake-N-Bake's Avatar
Shake-N-Bake
If you are curious about checking fuel volume to the bowl....
An empty fuel bowl (without a filter installed) will take about 12 seconds to fill up to the threaded area (where the cap threads onto...). If your pump times out and the bowl didn't over flow then you likely have a flow restriction somewhere. I hope this helps.
Side note:
Be advised that while doing this test you are essentially allowing unfiltered fuel into the bowl so it's prudent to drain the fuel again before installing the filter. This will help ensure that no unfiltered fuel finds it's way to the engine. A check valve will be released when the filter is removed so that effectively seals off any flow to the heads while performing the test.
Just an FYI...
Old Aug 26, 2013 | 06:10 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Maybe a member in your area of Texas can help you out with an AE or other scanner to check for codes!
Old Aug 26, 2013 | 06:58 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Somebody say TEXAS????? Where you at original poster?
Old Aug 27, 2013 | 08:20 PM
Tailgate77478's Avatar
Tailgate77478
Yes...Texas is a small state when it comes to the FTE Brotherhood. What city are you in?
Old Aug 28, 2013 | 06:47 AM
Tugly's Avatar
Tugly
It sounds like fuel delivery, but the oil pressure is part of the fuel delivery equation. HPOP, IPR, ICP, fuel pump and pickup, and injector O-rings are all suspect. You really need to get to somebody nearby with AE - click on the B.E.S.T. link in my signature.
Old Aug 28, 2013 | 11:19 AM
timmyboy76's Avatar
timmyboy76
Originally Posted by carltonwebb
When it cuts off, does it wind down slowly or does it shut off instantly?
Carlton, curious to know, where were you going with that statement?
Old Aug 28, 2013 | 12:01 PM
carltonwebb's Avatar
carltonwebb
If it winds down slowly, it would more likely be fuel related in my mind. Slowly chugs out may be another description of it
If it cut off instantly, i would lean more towards electrical.
I read e 350 in my original reply. I think those have steel tanks. Good catch by those of u who read the OP correctly. Sorry for the mislick
Old Aug 28, 2013 | 12:57 PM
Brother Les's Avatar
Brother Les
I have not seen anything about checking his oil level?
Old Aug 30, 2013 | 11:36 PM
NewFordUser
Sorry I Hadnt Replied Been Really Busy Working . Now The Truck Will Start And As I Hold The Pedal Down It Will Stay On But If I Let It Go It Will Die Down Slowly .
Old Aug 30, 2013 | 11:37 PM
NewFordUser
And I Live In The Southeast Region Of Texas . My Towns Name Is Pearsall , About 63 Miles South Of San Antonio .
Old Aug 31, 2013 | 03:17 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Pearsall? Southeast Texas? Where I am at, Pearsall is DEEP SOUTH Texas! LOL. Don't give up on that thing. We will get you fixed up and running right. Can you send and receive PM's yet?
Old Aug 31, 2013 | 09:46 AM
  #28
NewFordUser
Im Not Sure If I Can Recieve Pms , And I Really Hope So Man , If Y'all Can Help Me I Will Appreciate It Greatly
Old Aug 31, 2013 | 10:34 AM
  #29
ralleyclimber's Avatar
ralleyclimber
You came to the right place. There are some amazing guys on here. Dont give up. Correct me if I am wrong but you have 10 posts I think you can receive PM's now...???
Old Aug 31, 2013 | 12:59 PM
  #30
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Ok, go to the top left of this page. You will see a little box with a "UserCP" in it. That is your user control panel. That is where you can turn on the ability to get PMs (private messages), create an avatar, create a signature line, add your name to your posts or upload pictures of your truck/motor. You can also add an email address so we can contact you directly through email if you like. Sometimes, it is nice to receive an alert through email that someone has answered/responded to your questions in case they are urgent. Also, through PMs, we can exchange phone numbers and the like without the whole web seeing those numbers. Give the Control Panel a try...mess with it a bit. There is an option to "turn on PMs" in yours somewhere.
