Hot start issues again....
Old Sep 1, 2013 | 07:18 AM
  #31
mustang_309's Avatar
mustang_309
Anytime. Hopefully it doesn't happen again but if it does you will know why. That was an excellent piece of research done by creator.
Old Sep 17, 2013 | 07:00 PM
  #32
ramsay's Avatar
ramsay
It happened again. So I pulled the oil rail and checked the nipples like creator said and all 4 are loose. Some more than others but I'll do them all while it is apart. Without creator's link (https://www.ford-trucks.com/forums/1238249-fuel-injector-top-o-rings-seals-the-whole-story.html) I never would have figured this out. So now I get to sit and wait for parts and tool to arrive.
Old Sep 17, 2013 | 07:16 PM
  #33
mustang_309
Sorry it happened again bro but at least you know the cause and can put this to bed once and for all. Thank you for the update.
Old Sep 17, 2013 | 07:21 PM
  #34
BLADE35's Avatar
BLADE35
BOy these 05+ HPO Systems get better n better
What Year Was Creator Well he was 2005 as well
Oh and Creator looks to be on his second set Orings so Hope He found Good Ones
Another attaboy for 2003 LOL
Old Sep 17, 2013 | 08:15 PM
  #35
ramsay's Avatar
ramsay
As far as I know my Ex has the late 04 engine with the new style rails and old style pump.
Old Sep 17, 2013 | 08:17 PM
  #36
Piolet's Avatar
Piolet
True that!! It wouldn't let me rep you Benny.
Old Sep 18, 2013 | 09:17 PM
  #37
ramsay's Avatar
ramsay
I pulled some of the nipples out today and found one of the retainers in cracked and all the retainers have visible oil flow wear marks from where the oil was escaping around the oring. I ordered some Alliant Power orings (Kit AP0070) which should be here tomorrow. I have no idea where to look for a replacement retainer or even if I should reuse them as they do appear slightly worn. I may call International in the morning and price out the rail assembly from them as list from Ford is around $650 + tax (CDN). Pics are here. Ford Truck Enthusiasts Forums - ramsay's Album: 6.0
Recommendations and comments are welcomed.
Old Sep 18, 2013 | 09:55 PM
  #38
BLADE35's Avatar
BLADE35
Did you ever take IPR & ICP Readings @ Hi & Lo RPM
Old Sep 18, 2013 | 10:04 PM
  #39
ramsay's Avatar
ramsay
Yes they are perfect at cold start and when running. ICP is low (200-300psi) when cranking hot with IPR at 85%.
Old Sep 18, 2013 | 11:02 PM
  #40
BLADE35's Avatar
BLADE35
I want to Know what your IPR% was @ HOT Idle when it still Ran But Right before this started going Down
Did you ever See IPR that early in the Game
Old Sep 19, 2013 | 06:30 AM
  #41
ramsay's Avatar
ramsay
Hot Idle IPR was 24% +/-.
Old Sep 19, 2013 | 11:25 AM
  #42
ramsay's Avatar
ramsay
I ordered a rail from Ford today after seeing the condition of my orings, nipples and the cracked retainer nut. Imagine my suprise when I was told that there was a $75 core charge. Ford is taking these back in and rebuilding them which is why they won't sell individual repair parts. It would cut into the profit margin.
Old Sep 19, 2013 | 11:02 PM
  #43
BLADE35's Avatar
BLADE35
Thanks
Just what I thought
Old Sep 23, 2013 | 09:58 PM
  #44
ramsay's Avatar
ramsay
I got the new (Reman) installed and still had a long crank so I pulled the left side valve cover and found oil pouring out of #2 cylinder injector to oil rail seal. I then pulled all the seals from that side and found 2 more nearly ready to blow and one in perfect shape. Upon closer examination the one undamaged seal is a darker shade of black and is made of a harder stiffer material than the others. Is it possible that there are different grades of seals or different materials used by different manufacturers? Does anyone know what brand of seals the rebuilders use? The last ones I bought were from the Alliant Power AP0002 kits.
Old Sep 24, 2013 | 12:28 PM
  #45
ramsay's Avatar
ramsay
I called the retailer today and described my findings, who in turn called Alliant. The story I got was that Alliant had a bad batch (too soft a compound) of upper oil seals which explains why some of the rings were good and some were not. Apparently some of the rings I got were old stock defective and the good ones were new stock updated material. From what I understand Alliant will warrantee them if they are found to be defective. I'm not sure if all the issues creator experienced were the result of nipple seal failure or if crappy oil seals were partially to blame.
