step bumper receiver hitch
Old Aug 25, 2013 | 12:46 AM
HBL's Avatar
HBL
Do they make one that can bolt to a bumper of a 79 f 150 ranger using the existing holes?
Old Aug 25, 2013 | 12:57 AM
HIO Silver's Avatar
HIO Silver
Which bumper? Contour (aka "sport") or a dock bumper.
Yes, there are versions that can bolt to a dock bumper... it's essentially a 1/4-inch plate with a 2-inch receiver hitch underneath. Existing holes? I am not sure to which holes you are referring.
A better option is to find a later model Bronco with the same frame width and get its frame-mounted trailer hitch system... waaaaaay better than the dock bumper set up. I got mine at a salvage yard for a mere $26.
Welcome to FTE.
Old Aug 25, 2013 | 01:32 AM
HBL's Avatar
HBL
Thanks. Not sure of type of bumper, but it has the center hole for a ball and two smaller ones on either side. My truck is too tall for a small cargo trailer I need to pull. The truck is currently on loan to me, so I'm hesitant to do much modification to it and installing a frame mounted receiver hitch is a little spendy. The trailer only weighs approx. 1600 lbs. loaded and will only be pulled around town.
Old Aug 25, 2013 | 01:46 AM
HIO Silver's Avatar
HIO Silver
Ah... that info up front would have helped so we would have understood your situation.
I believe you have a dock bumper and are gonna be stuck btwn a rock and a hard place. I know of no drop systems for raised trucks with dock bumpers. Your option is to use a bolt-on plate receiver and then use a dropped tongue.
Dunno about "stock" holes. Drill... drill....drill.:
Acme Class III Step Bumper Hitch - For Flat Plate Step Bumpers | QC Supply
Old Aug 25, 2013 | 01:48 AM
HBL's Avatar
HBL
Thanks. I've been looking at those. I was just hoping to not have to drill.
Old Aug 25, 2013 | 10:32 AM
Blue and White's Avatar
Blue and White
The holes on the hitch plate *probably* line up with the two outer holes on the bumper. The hitch adapters HIO pasted are often stocked at auto stores, farm stores and maybe HF. You could measure and check. If drilling is required, it would be on the hitch adapter, not the truck. Those adapters are a light duty setup but with 1600 lb should be OK. I would re-check bolt tightness after towing a little bit.
CPT P
Nov 12, 2013 11:04 AM
xsqu1d
Apr 4, 2008 11:03 PM
2001gocougs
All Things Towing
13
Dec 10, 2006 10:15 PM
Rob88
Oct 31, 2004 07:56 AM
fishmanndotcom
All Things Towing
19
Oct 21, 2004 11:59 PM
