1978 - 1996 Big Bronco
NEED HELP DIFF INSTALL
Old Aug 24, 2013 | 09:31 PM
f1001969mike's Avatar
f1001969mike
had to do a pinion bearing on my truck, trying to get the diff back in but it wont go the shims are binding up and when i do get it to slide in the left bearing cap wont seat what the heck am i doin wrong
Old Aug 24, 2013 | 09:58 PM
Scifi266's Avatar
Scifi266
Did you set the bearing preload?
Old Aug 25, 2013 | 01:39 AM
rogue40's Avatar
rogue40
When loading a carrier that needs outer shims you need to use a housing spreader.
Old Aug 26, 2013 | 10:16 AM
Kemicalburns's Avatar
Kemicalburns
sounds like you need to take the diff into a shop and have a professional setup your gears now.
Old Aug 26, 2013 | 12:30 PM
f1001969mike
i finally got it installed , i had to use a diff from an axle i had out of an 83 after tightening the pinion down the carrier bearing caps seated just fine, although i also had to use the 83's axle shafts which means i have to change the rear drums to 83 drums because the center opening on the 89 drums is larger, yeah thats it, everything else between the 83 and 89 drums is identical so one i have those changed out i think im all set
Old Aug 26, 2013 | 12:34 PM
f1001969mike
the reason being is because the spider gears on the 89's original diff were badly chewed i found chunks of em at the bottom of the case they look like the made it through the ring gear and pinion seeing as how the truck no longer has RABS the fact that the 83 diff didnt have a tone ring for the VSS doesnt really matter
crucialprospect
21
May 13, 2018 04:00 PM
90turbo1
Sep 13, 2014 12:03 AM
78 Ranger
1997 - 2003 F150
Aug 12, 2012 08:59 AM
scatgo
31
Dec 27, 2008 12:43 AM
hatchet
Offroad & 4x4
Oct 30, 2006 07:26 AM
