Sponsored by: Real Truck
need more horses!!
Old Aug 30, 2013 | 03:59 PM
  #31
Hotpocket's Avatar
Hotpocket
as long as it is the same diameter it shouldn't matter
Old Aug 30, 2013 | 05:22 PM
  #32
Bently_Coop's Avatar
Bently_Coop
7 posts from the new user and all about more power for his V10 superduty. hmm...
I think we need to see some pictures of this truck. Before we continue to answer more questions. Should also think about checking the V10 section down below.
Old Aug 30, 2013 | 10:50 PM
  #33
dkf's Avatar
dkf
Originally Posted by 01twotonebeast
What if I go to a different tread tire but stay with same size rim but wider
If you go with a 285/75R16E it will be about 1" larger in diameter and 1" wider than the 265/75R16E that can stock with most trucks. Some trucks came with a 235/85R16E which is the same diameter as the 265 but 1" narrower. You can go larger to a 305/70R16 but they are getting too wide for the stock wheels (recomended wheel width) for a 305. A 305 is the same diameter as the the 285 but 1" wider. For a stock height truck the 285s are perfect IMO and that is what I run. The 285s and 4.30s will do ok but if you tow heavily on a regular basis you may want to consider 4.56 gears.
Old Aug 31, 2013 | 09:41 AM
  #34
Tugly's Avatar
Tugly
Just popping in. This is the first thread I've read on powering up a V10 and I find it interesting. While some may say it's a bummer that you are limited to a few inexpensive mods to power up, the other option could be a curse in disguise:
My 7.3L diesel has a lot more power than what I started with... but the transmission alone needed a $4K bump to handle tire-shred mode, the rear suspension needed ladder bars, and the added turboboost blew the intake plenums - requiring billet plenums. All of that was in addition to the $10K in engine mods. I know someone that went further than I did and he needed a whole new fuel system, bigger oil pumps (plural), major mechanical mods to the engine, and the engine alone took months to dial in.
I brought all that up to make this point: Powering up doesn't always go as easy one would like - the whole system was engineered in a balance and strengthening one link can make the rest of the system the "weak" link. Imagine thinking "I just wish I could go back to the way it was" with a smoking Buck$Zooka on your shoulder.
My diesel gets 16-19 MPG (depending on road/season/driving conditions), so I seriously doubt a gas engine can push 8000 pounds of glass, rubber, and steel while getting 17 MPG.
Old Aug 31, 2013 | 06:24 PM
  #35
pappy19's Avatar
pappy19
Yep, when I had my 2002 7.3, I figure I had at least $6,000 in mods not including the $4k for a new HD tranny and torqueconverter. To date I have spent the max that I can spend on my V-10 for "power"; Mikes 5 star, Airaid intake system and Magnaflow exhaust, total= $1,120. I've done other mods but not for the engine performance and won't as there is only a supercharger that can make it more power but I like it just the way it is. $20 oil changes, $15 fuel filters and $300 plug change; that's about it. I did just spend $125 for a replaced brake sensor for my cruise control to work again. That's the first $$ I have spent on this truck other than normal maintenance.
Old Aug 31, 2013 | 09:34 PM
  #36
MDSuperDuty's Avatar
MDSuperDuty
Bucks Zooka. That's phenomenal! I think any ride in SuperDuty form comes with a complete buckszooka. They cost a fortune to purchase, parts are more money due to heavy duty, fuel mileage is miserable in either form and the one with better mpg just has a higher fuel cost (let's not start an argument now). But man can they work!
artcat99zl
Modular V10 (6.8l)
Nov 18, 2014 04:44 PM
Daryl Hunter
Sep 15, 2004 07:25 PM
cjcathey2002
Jan 30, 2004 11:38 AM
