24yr Old Recall... Will be fixed... NOT under recall. LOL However it gets done idc.
The Dual Tank Selector Valve issue also applies to the F350 of same year. So if you experienced this please comment, Thanks!!
If you own an 1989 Econoline (Build may be 88) and have or have not had recall work done on the "Dual tank fuel selector valve" (350,000 VANS) or "PARK rolls freely on gear selector(110,000 VANS)...PLEASE let me know!!
AFTER A QUICK READ TELL ME WHAT YOU THINK I SHOULD DO TO HANDLE THIS??
I called Ford to inquire about if my van I bought had ever been serviced for the only 2 recalls issued for the 1989 Ford Econolines..
Not only had it NOT been.. They said MY vin had NO recalls associated with it.
After speaking with 2 customer service agents and 3 supervisors they say my van is not subject to the following recalls. But first the facts:
1. A couple months ago I buy this van used from orig owner w/ 100k mi on it. Owner states no recall notifications ever arrived.
2. He says after 3 years of ownership the van stopped engaging in PARK and a chalk and e-brake had to be used. Local dealer made 2 attempts and could not find problem.
3. I was driving along and experienced a loss of over 25 gallons of fuel all out the auxiliary fuel tank nozzle past the cap. Problem has not cured itself.
4. I am a paraplegic who does not escape from a burning vehicle or out of control vehicle very quickly or easily.
5. THIS VAN IS A 1989 FORD ECONOLINE E350 <---- Most important to remember since after reading the detailed info on the recalls "THEY DONT APPLY TO MY VIN"
Recall data for: 1989 FORD ECONOLINE
NHTSA Campaign Number: 90V101000
Manufacturer Campaign Number:
Make: FORD
Model: ECONOLINE
Year: 1989
Component:
POWER TRAIN:AUTOMATIC TRANSMISSION:GEAR POSITION INDICATION (PRNDL)
Manufacturers Involved: FORD MOTOR COMPANY
Begin Date Of Manufacturing:
End Date Of Manufacturing: 19891001
Recall Type: V
Potential Number Of Units Affected: 111000
Date Owner Notified By Manufacturer: 19900717
Recall Initiator: ODI
Manufacturer Responsible For Recall: Ford Motor Company
Date Report Received By ODI: 19900601
Date Added To File: 19900614
Regulation Part Number:
Federal Motor Vehicle Safety Standard Number:
Defect Summary:
UNDER CERTAIN CONDITIONS, THE SNAP RING THAT LOCATES THE PARK GEAR ON THE OUTPUT SHAFT OF THE TRANSMISSION MAY FRACTURE.
Consequence Summary:
WHEN THE GEAR IS PLACED IN PARK, THE PARK GEAR WOULD NOTENGAGE, ALLOWING THE TRUCK TO ROLL FREELY IF THE PARKING BRAKE IS NOT PROPERLYSET. THIS COULD RESULT IN AN ACCIDENT.
Corrective Action:
INSTALL IMPROVED SNAP RING AND REVISED TRANSMISSION EXTENSION HOUSING.
NHTSA Campaign Number: 91V146000
Make: FORD
Model: ECONOLINE
Year: 1989
Component:
FUEL SYSTEM, GASOLINE:STORAGE:AUXILLARY TANK:SELECTOR DEVICES
Begin Date Of Manufacturing: 19890201
End Date Of Manufacturing: 19910201
Recall Type: V
Potential Number Of Units Affected: 350000
Date Owner Notified By Manufacturer: 19911220
Date Report Received By ODI: 19910904
Date Added To File: 19910930
Defect Summary:
THE DUAL FUEL TANK SELECTOR VALVE MAY MALFUNCTION AND CAUSE AN OVERFILL CONDITION IN ONE OF THE FUEL TANKS, RESULTING IN AN OVERFLOW OF FUEL PAST THE FILLER CAP.
THE OVERFLOW OF FUEL PAST THE FILLER CAP CAUSES A FUEL LEAKAGE, WHICH CAN RESULT IN A FIRE WHEN EXPOSED TO A SOURCE OF IGNITION.
Corrective Action:
REPLACE THE DUAL FUEL TANK SELECTOR VALVE.
With your help at FTE then I hope to proove to ford that if the good/faulty part numbers associated to these same recalls....match mine... It should have been included in the VIN selection & faulty parts replaced along with all the others selected......
or is this the case....
Make: FORD
Model: ECONOLINE
Year: 1989
Component:
Recall Type: V
Defect Summary:
Corrective Action:
Make: FORD
Model: ECONOLINE
Year: 1989
Component:
Recall Type: V
Defect Summary:
Corrective Action:
I wish you luck on this.
A good caring dealer might offer you service on it but it's along shot.
Reason I say this is even on F150 from 2011 right to the 13s on the dealer lot there is shudder issues upshifting 1 to 2 and 2 to 3 when towing with brand new trucks right off the lot and they won't fix them.
The dealer is not obligated to unless the company provides a repair and reimbursement program.
Think you have an issue?
Think how unhappy owners are that pay $50,000 +/- and end up with an issue like this that won't be fixed.
Again I wish you all the best.
Ahhh ha!!
Local dealer said to bring it in after holiday weekend. They said they would be happy to fix it as long as there were no signs of abuse ( there are not ). However, they were adamant about letting me know it has nothing to do with the coincidental recall.
hey.... legal reasons.... i finally get it. Fix mine under recall... gotta fix others.
hell if they fix it by putting in 3 tanks i dont care lol
If you need to have this van fixed then put it in the shop and have it fixed at your expense. The car manufacturers have no liability to repair a vehicle after it's 8 to 10 years old. Also they may be telling you that your van did not get a recall notice because it was NOT manufactured within the dates of the vehicles that were failing. Example if they sent out a recalls to vehicles that were made between 11/87 and 6/88 but your vehicle was made in 10/88 then it wouldn't be included in the recall. On top of all this, manufactures usually only supply parts for a vehicle for 10 years after manufacture, after that it's whatever the dealers have in remaining OLD stock getting from a pick and pull or going aftermarket if available.
It doesn't matter if the the Original owner says he didn't receive a recall at this point in time it's his word against the car company, and trust me, the car company will win. I mean you're talking about a 33 year old vehicle that you think someone else should pay for the repairs on? Here's a link you can read for laws on recalls if you're interested in it https://www.hg.org/legal-articles/ri...-vehicle-38080 But if you think you have a case against Ford, well God bless you and I surely hope you have the resources to fight them for repairs of a 33 year old vehicle.
Harlan Hobbs
01-10-2022 04:23 PM
gman97005
08-27-2013 03:42 PM
Harlan Hobbs
1999 to 2016 Super Duty
08-25-2013 10:45 AM
Harlan Hobbs
08-23-2013 10:43 PM
cityjack
95
11-04-2012 10:59 AM
