Vibration help
Old Aug 24, 2013 | 02:04 PM
nintey4f150's Avatar
nintey4f150
Exclamation Vibration help
Have a 94 f150. 351w with 4r70w. I have a vibration in the truck from the 1500-2000 rpm range. It only occurs when driving. Tires have been recently balanced so I don't believe that's the problem. The front end has been all redone ballpoints tie rods center links and alignment so I also believe that is good. Balancer was replaced a few months ago as well. I don't notice and play in the u joints. And a couple months ago the diff was replaced. This problem started about 2 weeks ago. If I put it in neutral while it vibrates driving it goes away.. Only does it when driving
Old Aug 25, 2013 | 08:38 AM
nintey4f150
Wow no one?
Old Aug 25, 2013 | 06:17 PM
MeanGreen460's Avatar
MeanGreen460
I would pull the rear driveshaft out check for a binding or frozen up u joint .they should move freely both ways
Old Aug 25, 2013 | 09:19 PM
Ed Bamba's Avatar
Ed Bamba
Do as MeanGreen suggested. How many miles on your vehicle? Your u-joints can still be bad even if they have no play in them. Did you check for play with the driveshaft disconnected? I had a vibration on my truck and the u-joints were tight, so tight that I had a heck of a time removing them from the yoke. When they finally broke loose it fell out in pieces of rusted metal. I replaced all u-joints along with center support bearing. Vibration dissapeared.
Old Aug 25, 2013 | 10:19 PM
timbersteel's Avatar
timbersteel
I vote u-joints as well.
Old Aug 25, 2013 | 11:59 PM
nintey4f150
Yes it was the u joints which I replaced earlier today. Thanks guys
95fiveoh
May 4, 2018 10:59 AM
noimports
Apr 22, 2018 09:08 AM
DanielT28
Jan 31, 2015 07:20 AM
rlreed
1997 - 2003 F150
Mar 10, 2011 02:56 PM
MSC
Feb 10, 2006 08:20 PM
