Sponsored by: Real Truck
Adding integrated brake controller to 2008 F250
Old Aug 23, 2013 | 09:55 PM
beeser's Avatar
beeser
Besides the OEM brake controller itself and reprogramming the computer module what is necessary to add the factory brake controller to a 2008 F250. I noticed that the 2008 brake controller looks the same as the prior years and very different than the proceeding years.
Old Aug 24, 2013 | 02:16 AM
TexasRebel's Avatar
TexasRebel
I'm guessing by "proceeding" you mean "succeeding"
In 2008 you also have to change the master cylinder to one that accepts a second pressure transducer. In later years, I believe, the pressure transducer duties were combined and this is no longer necessary.
Old Aug 24, 2013 | 09:41 AM
beeser's Avatar
beeser
Thanks TexasRebel! Is the wiring for the transducer already there?
Old Aug 24, 2013 | 01:18 PM
TexasRebel's Avatar
TexasRebel
should be. Mine was.
Look for a connector near the master cylinder with wire on only one side.
Old Aug 24, 2013 | 08:56 PM
beeser's Avatar
beeser
Couldn't find the connector you described on the truck I was looking to buy so I passed on it. Thanks for the heads up.
Old Aug 24, 2013 | 11:37 PM
TexasRebel's Avatar
TexasRebel
hmm. I don't think it's ever not been there before.
If that's your only reason for passing, you might want to check again. I try to snap a picture tomorrow.
Old Aug 25, 2013 | 08:55 AM
beeser's Avatar
beeser
The wiring was not the only reason for passing on the truck but it was the one that tipped the scale. I can't take a picture of it now because of the distance involved but as I recall the harness had one lead going up to the front mounted transducer and another lead that doubled back onto itself to with a connector in between. The large bundle of wires lacked a smaller bundle attached to it that went to the back mounted transducer, which I found to be the case on another 2008 F250 having an IBC.
Old Aug 25, 2013 | 03:47 PM
TexasRebel's Avatar
TexasRebel
Just the same, here is the picture I promised for future reference.
The red circle is the blank connector that the harness is connected to if the rear transducer is not present.
The green circle is the new transducer with harness connected.
Old Aug 25, 2013 | 05:09 PM
beeser's Avatar
beeser
Looks like I'll have to go back for another try at buying it. BTW, the picture doesn't show or load.
Old Aug 25, 2013 | 07:52 PM
beeser's Avatar
beeser
I can see the picture now. So, the green circled connector attaches to the red circled connector when the IBC is not present? Thanks for posting the picture.
Old Aug 26, 2013 | 10:15 AM
TexasRebel's Avatar
TexasRebel
yes. it just keeps road grime out.
Old Oct 20, 2022 | 07:54 PM
gagapapa A's Avatar
gagapapa A
1st Gear
Number of wires in transducer connector
Wiring diagram shows 3 but unused connector identified by ford service tech has only 2. How many wires on yours ? Mine is 2008 F 250 diesel. Unable to see pix you posted earlier.
Old Oct 21, 2022 | 10:30 AM
nydiver's Avatar
nydiver
The second transducer (the one missing on the non EBC master cylinder) is a 2 wire. Its hidden right below the MC. Do you have the new master? If you want/need a BN in a bag one hit me up. I need it and my used non EBC cylinders out of my way. Make a nice deal
muddyforeman
All Other Items for Sale
Jul 2, 2016 10:25 AM
Diesel_Brad
All Things Towing
25
Sep 27, 2015 06:33 AM
RBALAN
Mar 23, 2013 07:30 PM
gregghealy
Sep 27, 2007 05:06 PM
Rickm518
All Things Towing
Oct 21, 2006 01:41 AM
