power steering conversion blues
Old Aug 22, 2013 | 09:52 PM
brutus67's Avatar
brutus67
hi too all you guys out there I have a question if you convert from manual steering to power steering what else do you have to change tie rods etc any help from you all would be great thanks
Old Aug 22, 2013 | 10:05 PM
HIO Silver's Avatar
HIO Silver
Old Aug 22, 2013 | 10:17 PM
brutus67's Avatar
brutus67
power steering blues
sorry I did not provide enough info my truck is a 69 f100 ranger long bed 2wd 300 cu six I ordered the gear box from car steering in ca I did not know till I spoke to the guy there that I could have got the whole kit from them pump pulley hoses etc for 550 bucks I could not find pulleys or power steering pitman arms anywhere but they had one nice guys to talk to as well
Old Sep 5, 2013 | 04:35 PM
brutus67's Avatar
brutus67
well I got my power steering gear box from the guys at car steering in c.a with the pitman arm fitted I will be picking up the secondhand pump pulleys brackets etc when I go to charlotte for the fall autofair from tom who runs flashback f100,s so with some luck I can get it fitted soon. a question I have is will the linkages that are on the truck at the moment bolt right up to my new gearbox or do I change anything any help from you all would be greatly appreciated thanks in advance
Old Sep 6, 2013 | 12:15 AM
lizardman1's Avatar
lizardman1
What box, Saginaw or Bendix?? 2 or 4wd. Need accurate info if you want answers.
Old Sep 7, 2013 | 10:31 PM
brutus67's Avatar
brutus67
sorry lizardman 1 my truck is a 69 ranger long bed 2wd I got a Saginaw box I will be picking up my ps pump brackets 2 groove fan pulley etc on the 20th at the car show in charlotte. then I will start the conversion tom from flashback f100,s is going to supply me with a fully reconditioned automatic power steering column so I can change from manual 3 on the tree to automatic it should make it easier for this old man to steer so my buddy tells me
Old Sep 8, 2013 | 05:37 AM
jowilker's Avatar
jowilker
You could have been way ahead with buying a 73-79 dentside donor and have all the parts for your conversion including the steering column that is required.
John
Old Sep 8, 2013 | 08:02 AM
lizardman1's Avatar
lizardman1
Brutus, Jowilker is right on about getting another parts truck. I had a 73 truck I stripped down then sold, keeping all but the cab, bed and frame. Good luck with your conversion!
Old Sep 8, 2013 | 10:48 PM
brutus67's Avatar
brutus67
thanks guys for your replies yes I am aware I could have used a 73-79 donor truck problem is timing & money neither came up at the right time lol. at least the way I am doing it I will have all new parts next thing is to get a rebuilt column & after that get a fully reco auto trans and at my age I will never wear the old girl out . one of the things I don't like about my truck is that huge steering wheel as much as I want to keep my truck almost stock I may finish getting one of those wood bound wheels with the alloy spokes I am not really fat but the wheel almost hits my gut maybe coz I have got short legs lol btw lizardman cant wait to see how your new truck turns out best of luck brother
Old Sep 9, 2013 | 05:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Bendix P/S: 1966/68 F100/250 2WD; 1969 F100/250 2WD before serial number D96,001.
Ford/Saginaw P/S: 1969 F100/250 2WD & F350 from serial number D96,001; 1970/79 F100/250 2WD & F350; 1976/79 F100/150 4WD; 1977 F250 4WD from serial number Y20,001 (not High Boys); 1978/79 F250 4WD.
P/S not available on 4WD's until 1973 and then only as an option. 1973/75 F100 4WD, 1975 F150 4WD available with Garrison Power Assist P/S.
1973 F250 4WD's, 1974 F250 4WD's before serial number T80,001 available with Garrision Power Assist P/S, but most of the parts do not interchange with Garrison F100/150's.
1974 F250 4WD's from serial number T80,001, 1975/76 F250 4WD's, 1977 F250 4WD's before serial number Y20,001 (High Boys) available with Bendix P/S.
With Power Assist P/S, the manual steering gearbox is used, as it has nothing to do with Power Assist!
Old Sep 10, 2013 | 12:59 AM
bmuhlbach's Avatar
bmuhlbach
I had to get a pulley that bolted to the crankshaft pulley for the extra belt on my 68 with a 360.
jmstuede
Jun 7, 2017 01:41 PM
jpaltauf
Sep 2, 2013 08:47 AM
SteveEford1
Nov 23, 2010 12:52 PM
mabigredtruck
Dec 15, 2009 12:10 AM
76fordo
Mar 13, 2008 09:50 PM
