Sponsored by: Real Truck
5.4 engine #4 plug problems 2005
Old Aug 22, 2013 | 04:01 PM
craigm1's Avatar
craigm1
Hi Guys, I'm looking for any ideas on how to get the spark plug out of cylinder #4. I have the kit to take out the base of the plug out of the head if it breaks off. But I can't get the plug out. I think the plug broke off but not the electrode. So the electrode is caught up in the porcelain tip of the plug. It's pretty tight back there with the a/c lines and fuel rail and other stuff. Any ideas would be greatly appreciated. I tried needle nose but they just don't grip it right, to get enough force to pull it. These are the plugs with the extended tips.
Thanks Guys
Old Aug 22, 2013 | 05:37 PM
Wolfboro's Avatar
Wolfboro
Are you using compressed air to blow off the debris out of the spark plug hole ?
It could make the difference.
Good luck,
Old Aug 22, 2013 | 06:40 PM
redford's Avatar
redford
FTE Leadership Emeritus
Are you following this procedure, exactly?
http://www.phila.gov/fleet/Warranty%...-06%20FORD.pdf
Old Aug 25, 2013 | 09:22 PM
phillycincykid's Avatar
phillycincykid
that is the most useful document to come from the city of Philadelphia in a long time
Old Aug 26, 2013 | 04:09 PM
craigm1's Avatar
craigm1
Hey, I tried the compressed air but with no luck, I bought a pair of needle nose vice grips that I will grind down and maybe pull it that way. I will keep you guys posted. Thanks
Old Aug 26, 2013 | 04:57 PM
redford's Avatar
redford
What mode of failure do you have?
Old Aug 27, 2013 | 07:49 AM
craigm1's Avatar
craigm1
I kept getting the codes 304, and 300 so i decided to start with a mew plug. Then the plug broke off and that's where I am now. I also went almost exactly by the Ford recommendations for changing the plugs.
04f250driver
Nov 6, 2017 05:15 AM
bassinbick
1997 - 2003 F150
Dec 9, 2016 08:13 AM
hans2112
Aug 5, 2012 08:16 AM
zacharytown
Jul 25, 2009 09:45 PM
invader
Apr 6, 2003 02:04 PM
