A short-shaft, 10-spline TKO-500 to an OEM bellhousing;
A standard shaft, 10-spline TKO-500 using a spacer plate to an OEM bell; or,
A standard shaft, 10-spline TKO-500 using a QuickTime bellhousing.
A 26-spline, TKO-600 using a 26-spline clutch disc, plus a spacer plate.
