Radiator pressure
Old Aug 24, 2013 | 11:22 AM
johnny williams's Avatar
johnny williams
Bump for more information.
Old Aug 24, 2013 | 03:33 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Oil in CAC tubing to a varying degree on all 6.0's. It comes primarily from crankcase blow-by.
Old Aug 24, 2013 | 04:29 PM
steelhead2's Avatar
steelhead2
Originally Posted by Rusty Axlerod
The pressure should be caused only by the expansion of the coolant as it heats up. If you relieve pressure after it's up to operating temp and it builds up again (without cooling and re-heating) then somthing is getting into the cooling system. Likely air, likely headgasket.
But dont forget when the t-stat opens youve got cooled water entering the engine taking on heat, causing it to expand again. Youll still have pressure even after youve bled it off. All the water isnt at operating temp all the time. Agter you go for a drive feel the top hose versus the bottom hose, there'll be a big difference in temps.
Old Aug 24, 2013 | 05:37 PM
johnny williams
Yes steel, there was a 20* dif between the thermostat neck and the top radiator hose at the neck and a 20* dif between the top rad hose and the bottom rad hose. I replaced the water pump the temps are all very close now. The engine temp is alos much more stable and the engine coolant and oil temps are VERY close now. Still building 16 + pounds in the rad. Starting to see the dollars fly out the window again. Doing a cooling system flush with prestone flush, started earlier today, have run through three hot cool cycles. Will drain Sunday morning and flush two or three times befor adding anti freeze.
Old Aug 25, 2013 | 03:27 PM
johnny williams
Any body want a 2005 ext. cab short bed 65xxx miles new water pump, thermostat, new cooper tires?
Old Aug 25, 2013 | 07:47 PM
Poor'it in'her's Avatar
Poor'it in'her
do you mean you're getting oil on your oil filter housing, the cooler is way down beneath that you cannot see it withoutpulling it out of the front engine reservoir.
Old Aug 26, 2013 | 06:15 AM
johnny williams
No, I said; no oil in water, no water in oil, no diesel in the water.
Johnny Be Cool
Sep 9, 2015 10:50 PM
Scoop531
Dec 29, 2013 05:36 PM
npccpartsman
Aug 17, 2011 11:29 AM
hammer65
Dec 26, 2010 05:31 AM
sandhillmike
Sep 9, 2007 09:35 AM
